510 on Speed Vision
510 on Speed Vision
Did anybody catch this 510 the other day on Speed Vision. I think the show is called Sports Car Revolution. they do a segment called Dyno Truth or Dare where they as the car owner what they think the HP is then they dyno it for the actual numbers. The 510 was pretty nice, comming in at around 470 HP.
I saw another time when some guy that had pumped around $50,000 into his Honda thought that it produced around 500 HP and was devestated when it came in at around 170 HP. I guess that he did not realize the body kit and stereo did not increase the HP.
specs.
Specs on the car.
Car ...............................….... 1972 Datsun 510
Class .........................…....... IHRA Hot Rod
Engine……..............…........... 383 cid small block Chevrolet built by Scott Conrad making 475 hp at 11:1 compression with Edelbrock Victor Jr aluminum heads & Super Victor intake, Crane roller valve train, Holley carburetor & electric fuel pump, MSD Crank trigger’d ignition
Headers ...............…............. Custom-built and JET-HOT coated
Transmission………............... Air-shifted 2 speed Powerglide with 8" torque converter
Rear ..............................…... Ford 9" with 4.56 gears, Strange spool & axles and Koni coil over shocks
Chassis ...........................…. 2x3 tube chassis with legal roll cage, 4 link rear suspension, A-arm independent front suspension with rack & pinion steering and disc brakes
Electrical .........................…. Painless wiring control panel & fuse block along with Dedenbear delay box & GRE ProStop throttle stop/launch controller
Instrumentation .............….… Autometer UltraLite gauges
Weight ..............................….2575 lbs
Fuel ................................…...VP Fuels “Red” 110 octane leaded gasoline
Lettering .........................….. Computer-cut vinyl by F & M Signs
Safety Equipment ..........….... RCI
Thanks also ....................…... Bryan Gilmore & Associates Building Contractors
Top Quality Transmission
Steel City Spring Service
WIX Filters / Victor Reinz Gaskets
Pennzoil
Pennzoil
RE: specs.
That's gotta be the cleanest drag 510 i've seen - cool!
RE: specs.
Is it just me, or does it look like a skeleton driving? Probably a beleclava and sunglasses, but still. Kinda creepy.
richard norrish
- MUNSTERSIZED
RE: specs.
now that's a 510 that should be in any one's yard ooooh yaaaaa !
IT'S NOT JUST A COMPACT, IT'S A STILE ON WHEEL'S!....ooohhhhh yaaaa
RE: specs.
Those wheels are gross, but you can't argue with 475hp... I thought the McKinney Drag 510 pre-flames was cooler (and nissan powered).
RE: specs.
speaking of speed vision, i saw a box flared 510 racing without a grill or lights in a commercial for something. it was very sweet, i think i was watching a show on the Hemi Challanger's or something.
-1988 Red Jaguar Solvereign, Cold Airintake, Exhaust, Tint, Alpine Sound System.
-1972 Black 2dr Datsun 510, slammed with Built L20B
RE: specs.
that was an ad for the SCCA Run-Offs.
today's the last day.
richard norrish
RE: specs.
What's funny, is that that is basically a standard hotrod: Mustang II front clip, Chevy small block, ford 9"... Of course it has to have Weld Draglite wheels! I'm just curious why they decided to shell it in a 510 instead of a Pinto or Nova?
At 2600lbs, it's no ultralightweight (I think that's about stock for a '66 Mustang minus interior)
I'm not just a normal nerd. I've specialized.
I'm a "Car Nerd"
I'm a "Car Nerd"
- MUNSTERSIZED
RE: specs.
I was just happy to see a 510 popin a wheelie but it be cool to see one nissan powered.
RE: specs.
Nissan makes V8's for its trucks doesnt it? i think you should go for it.
RE: specs.
There've been Nissan V8's in cars for over 10 years now, food for thought, but no manual transmissions that I've heard of.
RE: specs.
does the new Frontier come with the V8, now that its been updated and made bigger? It should come with a manual option, no?
with all the interchagability of Nissan parts, motor, trannies, you think something beefy would fit. From the Z32/33 or something.
richard norrish
RE: specs.
Nope. No V8. Maybe next year?
But a 4L V6 sounds kinda good to the ears....
Name
QR25 VQ40
Cylinders
I4 V6
Cam Design
DOHC
Configuration
Longitudinal
Head/Block
Composition
Aluminum/Aluminum
Displacement
(liters)
2.5L (2,488 cc) 4.0L (3,954 cc)
Horsepower
154 HP@5200 RPM 265 HP @ 5600 RPM
Torque
173 lbs.-ft. @4400 RPM 284 lb-ft @ 4000 RPM
Bore/Stroke (mm)
89/100 95.5/92
Compression Ratio
9.5:1 9.7:1
Name
QR25 VQ40
Cylinders
I4 V6
Cam Design
DOHC
Configuration
Longitudinal
Head/Block
Composition
Aluminum/Aluminum
Displacement
(liters)
Horsepower
Torque
Bore/Stroke (mm)
89/100 95.5/92
Compression Ratio
9.5:1 9.7:1
richard norrish
- MUNSTERSIZED
RE: specs.
cool info there norrish, but has any buddy seen a 620 trk say 78 with a vg30 in it ?
