Correct Drive Shaft Bolts
2DoorJim
Postby 2DoorJim » 13 Sep 2014 15:43
Installing my drive shaft and I've lost the bolts. I found several correct length but different bolts in my 25+ year old box of hardware but I'm not sure if there is a grade issue between them.
Would someone know which is correct? or, are these all OK, or wrong...
Image[/url]
Re: Correct Drive Shaft Bolts
Postby James » 13 Sep 2014 18:14
I think the driveshaft bolts are shouldered (going from bad memory).
I can check as the engine (and driveshaft) is out of my car, and I can take a pic of the bolts and will post up later tonight…..
2DoorJim
Postby 2DoorJim » 13 Sep 2014 18:35
Thanks for the reply James, all three of these types have shoulders, and they are the same length, correct looking length. It comes down to grade. Not sure if one of these is cheese, like grade 0, 2, or 5 equivalent when I'd think the correct bolts for here must be more like gr 8 or 12.
JordanTr
Postby JordanTr » 13 Sep 2014 19:45
I have 4 lil bolts in a bag that says "510 DS bolts". Walking to shop now... pics coming in hot!
JordanTr
Postby JordanTr » 13 Sep 2014 22:09
Here's what I used. Not sure if it's OEM or not but it came out of my car. Shouldn't go wrong with a properly torqued class 10.9 or 12.9 bolt. It's 25mm below the head, fully threaded (no shoulder).
Postby Byron510 » 14 Sep 2014 20:39
The factory bolts are definaterly shouldered bolts, but I can not give you an exact example or photo.
I do know I replaced mine with new the last time I removed the transmission and replaced the clutch - and they were still available from Nissan (2009 I think).
I can tell you for sure that they have 12mm hex heads.
2DoorJim
Postby 2DoorJim » 14 Sep 2014 22:37
Jordan, Byron, thanks both of you for the feedback. I scrounged up four of the "TR" bolts (the ones in my bucket did have shoulders). I put a mic on them and got .314 versus my other two styles in my picture which were ~.312 which makes me think Datsun used close tolerance, less likelihood of working loose perhaps. They did press in a bit tight.
I also think I found my original bolts, they were actually 5/16 NF gr8 without shoulders, hence why I couldn't find them earlier. I might be making a big deal out of nothing but I'd rather not have this equipment come apart at 7000 in fifth, if ya know what I mean.
Thx.
Jim
Ps driveshaft is in, still needs half shafts, intercooler tanks, and a bit of exhaust, then install oil, anti, brake juice and it'll be ready to fire. Heading out for a week of vacation first though! My patience is wearing thin here, its been about a year to this point.
Postby okayfine » 15 Sep 2014 06:17
Any Subaru we used to rob the diffs out of will use the same/correct bolts. Always has been reported that full-threaded bolts ended up working loose over time.
Postby Three B's Racing » 15 Sep 2014 06:32
What Julian said. The DS bolts do have a shoulder and do fit snug as I recently replaced mine with factory pieces when I did my clutch. I picked up the DS bolts about 6 years ago at Puenty Hills Nissan in La Puenty, CA while visiting friends and family. Sorry I didn't get part numbers just four bolts, nuts and washers in a plastic bag.
Postby okayfine » 15 Sep 2014 07:58
BOLT-HEX M8X1.25 08120-82510
zKars
Postby zKars » 17 Sep 2014 07:39
I got a bin full of Z drive shaft bolts to choose from if you want to come over and hunt. Should be home this evening. Still haven't seen this stunning 510 of yours....
Return to “General & Technical”
Users browsing this forum: No registered users and 0 guests
