Black and Blue '68s
- Mattndew76
Re: Black and Blue '68s
Right
cool project Joel- I am part of that demographic
Just looked this up Right is right, I need some for the M...greenthumb wrote:Right
- Mattndew76
Joel tell us a Christmas story.
Did you do more cool stuff to the car?
No great updates BUT I do have some stickers.joel@armoredmobility.com
$3.00 + $.50 postage = $3.50 email me at: Joel
Got about half the build (3 coats high solids urethane topcoat, 3 to go) of the thickness of film I need on the finish before I cut and polish, ebony is very porous with "cracks" in the surface to fill.
I have had many side marker lights through the years for the '68 that had the bolt support bracket on the back of the lens, rusted through or almost through like this:
So I decided it was a shame. I found some paper thin stainless sheet: Then I cut a couple little of patches for inside the bracket Using some aircraft frame type epoxy, stuck them inside Then added the shellJoel
Joel my friend, you must have an incredibly high tolerance for pain, because you've set new levels for the definition of the word painstaking on this build. As always, my hat is off.
Just got my EDIS trigger wheel sensor bracket from the machine shop:
- rendering
- pickup bracket.JPG (27.58 KiB) Viewed 4606 times
- WP_20150617_001.jpg (66.11 KiB) Viewed 4606 times
- WP_20150617_003.jpg (55.44 KiB) Viewed 4606 times
- WP_20150617_004.jpg (50.15 KiB) Viewed 4606 times
- WP_20150617_006.jpg (82.09 KiB) Viewed 4606 times
- WP_20150617_009.jpg (74.77 KiB) Viewed 4606 times
Made up a divider/reflector for the early Euro front turn signal assembly. Required some "tooling". I use the word loosely!;)
so much win!
You know, you have to be happy with the result.
Great job.
Great job.
thanks guys
