New potential products for 510's and Datsun from Mattndew76
Mattndew76
Re: New potential products for 510's and Datsun from Mattndew76
Post by Mattndew76 » 15 Feb 2016 19:36
R200 bars complete.
eastbaysolo_73
Post by eastbaysolo_73 » 15 Feb 2016 21:24
Those came out bad ass!
My build thread
Mattndew76
Post by Mattndew76 » 19 Feb 2016 09:00
I am looking into making some R160 CLSD bodies.
toylet
Post by toylet » 07 Apr 2016 22:31
Hi Matt
Can you make a run of these adapter brackets?
http://forums.hybridz.org/topic/124495- ... -on-a-s30/
Possibly a little cheaper than this as I can buy my own bolts and don't need the anodize.
This would be good for a 510 guy that has 280zx struts and wants to run the z32 brakes and keep 4 lug.
z32 brackets.jpg (121.08 KiB) Viewed 3244 times
89mm to 100mm brackets.jpg (124.16 KiB) Viewed 3247 times
Mattndew76
Post by Mattndew76 » 07 Apr 2016 23:03
I have a set of ZX struts on my floor.
Just need either one of those brackets to dimension and Z32 brakes :D
Mattndew76
Post by Mattndew76 » 07 Apr 2016 23:08
Holy cow they want $185.00 for those!!!
Ha ha ha ha ha $125.00 easy on this end.
toylet
Post by toylet » 07 Apr 2016 23:27
They made those brackets for a 296mm rotor.. too big for 510. I was thinking if you could make them work for a 280mm rotor using the aluminum 1990 N/A Z32 caliper. The 2003 hyundai sonota rotor is 280mm tall and 26mm thick. Which would be perfect for this set up. If I send you a caliper and a rotor, could you fab a bracket up from that?
Mattndew76
Post by Mattndew76 » 07 Apr 2016 23:33
How soon do you need this stuff back?
I am under a few pounds of production ATM. I want to make these though.
toylet
Post by toylet » 07 Apr 2016 23:41
I am in no hurry.. i only have the calipers. I could just ship the caliper to you. Than you can borrow a cheap rotor from autozone and return when you finished with mock up. So we wouldnt have to ship a rotor back and forth. Pm your shipping address if that is okay with you.
Mattndew76
Post by Mattndew76 » 07 Apr 2016 23:47
I will buy a set of rotors. So I can do this on my 1200 coupe.
toylet
Post by toylet » 07 Apr 2016 23:53
Also the closer we can get the rotor and caliper to the strut tube, the better. That way the face of the wheel clears the caliper.
OUTthere
Post by OUTthere » 08 Apr 2016 08:39
That bracket looks alot like mine! If I can be of any help let me know.
Oh ya, mine is for the 296mm
fj is killing me & datsun stuff 001.JPG (462.48 KiB) Viewed 3199 times
toylet
Post by toylet » 08 Apr 2016 08:49
Caliper looks close to strut mounting ears.. I wonder if it is even possible to get it closer to use a 280mm rotor? Maybe 296mm is the smallest?
Mattndew76
Post by Mattndew76 » 08 Apr 2016 13:11
OUTthere wrote:That bracket looks alot like mine! If I can be of any help let me know.
I think you even asked me if I wanted to use your adapter brackets too......
OUTthere
Post by OUTthere » 08 Apr 2016 13:20
Ya, think I did. Well my offer still stands, whats mine is yours.
