Car and motor look amazing! The intake manifold is simply a work of art, exactly what I had envisaged for my L series turbo project
What thickness pipe did you use on the exhaust manifold? Im thinking of going along the same lines design wise, not sure if one could make it look much different due to space??
Is there a specific reason why the injectors are mounted right next to the intake ports? I've been told its slightly better to mount them a slight distance away so as to better atomise the fuel before it enters the port?
What type of head gasket are you guys using? How thick is it too? I was thinking of making one out of copper, but have heard that they do not seal very well most of the time.
Do you use the standard intake/exhaust manifold gasket?
Sorry for all the questions in one post, I'm just really excited to see someone else doing a turbo conversion on an L motor
(man I sound like such a noob lol)
