Interesting ebay Finds
Re: Interesting ebay Finds
What's the real quality difference in your eyes?
If you have to space this one out and you have to space the Champion out to make either bolt up, then...?
hmm besides the koyo being shinier, the drain cock on the koyo rad is at the bottom of the tank not the middle. it has a provision for a thermo switch in the top tank.with the top tank being squared off rather than tapered allows for greater capacity. the welds are straighter and more consistent throughout. the core is evenly spaced between the tanks and appears to be designed from the start to be that size. were as the ebay rad looks like it was once a larger core that was cut down to meet the dimensions.
I wonder if the koyo has a slightly different bottom outlet (or if it mounts closer to the front support) as the bay (champion) radiator was essentially interfering with the bottom hose and the alt. pulley. Mine works, but its amazingly tight.
There have been a few people that had those champion radiator crack.. or fail. Even after getting a replacement, it would fail.
The koyo is a bit more. I got mine for about 250 shipped. It fit just fine with the stock alt, and an IR alt. No regrets. Wouldn't recommend the eBay radiator.
71 510 Goon, 71 2 door 510, 69 4 door 510, 92 300ZX TT, 84 720KC 4x4
I wonder if the cracking issue is dependent on how you mount it. What are the failure modes?
Yes, you shouldn't have to monkey with the mounting, but with the Champion at least, you do. But, if you do, are there still failures? I mounted mine with rubber sway bar end link bushings, and only tightened three of the four mounting bolts to allow it to expand as necessary.
If it were mounted rigidly to the core support, I could see that being a problem, especially as you'd be flexing the mounting points on both sides since the bracket doesn't mount flush.
They are mounted the same way as stock. Right to the core support with no insulators. The the welds on the tank I believe.
On either the ebay or the Koyo you have to space it out about 6mm to clear the lip on the core support.
- KiKiIchiBan
Wow that's cheap, there is one in the garage with my Coupe somewhere. Maybe they're worth more over here or RHD. Nice RX3 in the background too.510rob wrote:http://www.ebay.com/itm/122055385764
I was wondering why is it cheep?KiKiIchiBan wrote:Wow that's chea
very cool looking in a skyline got it on with a celica kind of way
local 510 showed up on cl this morning http://vancouver.craigslist.ca/pml/cto/5701168915.html
Im always amazed at how many dimes that are stashed away.
- McShagger510
That 510 was for sale around here in East Van for less than half that asking price about 6-8months ago. HA!
'91 Nissan truck *SOLD*
'02 TOYOTA Tacoma
'02 TOYOTA Tacoma
Re: 71 skyline 2000gt-r
surprised to see this auction mentioned in a local news paper : http://bringatrailer.com/listing/1971-n ... 2000-gt-r/
who wants it ? what will it fetch ?
Saw that on BaT a few days ago - I'll fetch over 100K I'm sure. I have to admit, it's pretty original. And it's been a while since I've seen one at stock ride height!
An actual S20 KPG? Yeah, way over $100K. This one hit $190K in August:
http://www.goodingco.com/vehicle/1972-n ... -hakosuka/
- McShagger510
Sotheby's $242,000 :
http://www.rmsothebys.com/lots/lot.cfm?lot_id=1067939
Best looking Nissan/Datsun made - big brother 510! Always loved these cars and every year the price keeps gettin' crazier.... *sigh*
'02 TOYOTA Tacoma
'02 TOYOTA Tacoma
