identification of nuts and bolts
Looking for a example of the nuts and bolts used for door hinges, hood and trunk
thanks for your time
Re: identification of nuts and bolts
hinge to body are the same as trunk to hinge fillips with captured lock and flat washer
door to hinge are the 2 middle cards full of bolts with a raised #4
hope this helps. more on bolts in my build thread http://www.the510realm.com/viewtopic.ph ... &start=180
thanks
the hinge to frame is a nut and bolt
that I can't seem to find in my bucket
I count 10 total
and still can't find a match
but I did find this picture
[/URL]
I count 10 total
[/URL]
On the left (m 8x1.25) is door hinge to body and trunk hinge to trunk lid. Middle (m8x1.25) is hinge to door. And on the right , (m6x 1) is hood , both hinge to body and hood. As well as fender to body.
- IMG_20161107_152636.jpg (593.97 KiB) Viewed 5653 times
Someone has messed with those hinges. The hinge is threaded for a bolt at the hinge to body.
oops
my mistake your right
so hinge to door ( the middle one)
is just screwed into the door ??
and the bolt to frame uses a nut
no nuts required on a pl510, hinge has threads doors have captured nuts .......looking at your pic thats not a pl510 or at least any door pillar I have seen.
thats just a reference not my car
sorry for the confusion
- The Taterhead
Looks like a 710 (the orange car)
I found a picture of the bolts used for the gas door
[/url]
[/url]
anybody have a picture of the 1/4 window screws? (screw hinge to frame)
and also need the set up
for the hood latch?
thanks
for the hood latch?
thanks
