Wiring Harness
Mr0erick0
Wiring Harness
Post by Mr0erick0 » 09 May 2017 21:48
Hey guys/gals! Im about to purchase an EZ wiring harness for my 510 but after reading that I would need crimpers? From vintage connections. I need some advice on what I actually do need haha first time ever messing around with wires.... :mrgreen:
Running a L16 so no idea how many wires I actually need, etc.
510wizard
Re: Wiring Harness
Post by 510wizard » 10 May 2017 08:53
Why are you replacing the factory wiring? If you need new connectors on the factory wiring , then I highly recommend the Vintage stuff. Just buy what you need plus the crimp tool or better yet a connection kit from them( comes with connector and tool). They will make up a kit for you if their standard kits won't do. They are great to deal with.
Mr0erick0
Re: Wiring Harness
Post by Mr0erick0 » 11 May 2017 16:15
I don't have any wiring in general unfortunately.
yenpit
Re: Wiring Harness
Post by yenpit » 24 May 2017 08:19
Sent PM! I have a nice clean 68 dash harness, might have engine compartment but they are always crusty, needing re-wrap & likely some repairs. Re-wiring a Datsun with an aftermarket kit is a BIG task, especially if you have never done wiring work before!
72 510 4dr
80 720 pickup
LOTS of parts!
2000 Impreza Outback Sport
2002 Forester
Re: Wiring Harness
Post by okayfine » 24 May 2017 22:10
Recommend you get a wiring diagram for your car and study it long before you start running wires. A universal aftermarket harness is fine and good, but it won't be a complete solution for you. A 510's headlight switch has five wires on it - how many wires is the aftermarket harness sending?
Your first wiring project being a complete rewiring of your car isn't likely to go well. I'd pursue a stock harness and repair as necessary (with said wiring diagram). Year and model of your car also matter. '68 is different from all, wagons are different from sedans, for the most part the late sedans will all be similar, with a few oddball wires for '73 two-doors.
Re: Wiring Harness
Post by okayfine » 25 May 2017 06:10
DQ Volume 5 Issue 3 - Tech How-To: Troubleshooting Electrical Systems: Part One - Automotive electrical system fault diagnosis may be the most feared work for the backyard mechanic. Many people view electrical systems as a sort of black magic, best left to professional shops. This may hold true for newer computer controlled vehicles that rely on special diagnostic tools. This is definitely not true for older cars like our 510s that don’t utilize computers.
DQ Volume 6 Issue 1 - Troubleshooting Electrical Systems: Part Two - In part one we explored some basic electrical circuit types, general components, and a simple test case. In part two we’ll dig deeper into the different electrical components along with their specific purpose.
DQ Volume 11 Issue 3 - Tech How-To: Fuse Box Identification — Nissan used different fuse boxes for different 510 model years. DQ presents an illustrated guide for 510 fuse boxes to help you figure out which one you have, plus circuit diagrams in case you want to build your own.
https://drive.google.com/drive/folders/ ... 0M28?hl=en
