'69 510 - Lysholm Twin-Screw Project
Re: '69 510 - Lysholm Twin-Screw Project
Post by two_68_510s » 14 Jun 2017 16:03
THAT is a very cool idea! And well executed!
Post by 510rob » 14 Jun 2017 16:51
I guess you'll have a Lysholm sleeper-charger on your motor. :P
VelvetHammer
Post by VelvetHammer » 09 Jul 2017 18:42
two_68_510s wrote:THAT is a very cool idea! And well executed!
Thanks!
The guys on the Motec forum gave me this advice which I figured was worth sharing:
From a heat point of view you wont have any issues mounting it like that, Don't bother with the fan it won't make any useful difference, unless your have extremely high ambient temperatures (ie more than 70-80 deg C).
You shouldn't mount any vehicle electronics with the connectors facing upwards. Condensation or and any water can run down the wiring and then pool on the top of the connector/case. It will eventually work its way into the device with heat cycling. You should mount them with the connectors facing down to reduce the chance of this happening.
It is always preferable to have some form of damping/rubber mounting as part of you mounting solution to reduce the vibration seen by the electronic components.
So there's that...
VelvetHammer
Post by VelvetHammer » 09 Jul 2017 18:43
510rob wrote:I guess you'll have a Lysholm sleeper-charger on your motor. :P
Hahaha I see what you did there :-)
VelvetHammer
Post by VelvetHammer » 26 Aug 2017 19:18
Well I got some parts in and put some wrench time in on the car a few weeks ago.
I finally pulled the trigger and mounted the coils and fuel filter.
The firewall is filling up fast so I'm not sure where I'm going to eventually put the remote oil mount. I might be able to put it on the shock tower but I have to keep in mind the future supercharger placement with will eat up all the space on that side.
Based on my previous post that showed some questionable looking front wheel bearings I decided to replace all of them along with the races. When drifting out the races I got sloppy and gouged the surfaces in a few spots. On closer inspection it looks like my dad may have done the same in years past. Like father, like so I suppose. I took some 1,000 grit paper, lightly sanded them smooth again, then flooded it with brake cleaner to get the grit out.
Here's the bearing grease I'm using.
Here are the bearing sets with part numbers if anyone need them
I couldn't remember the direction of installation for this seal so I installed it as in the picture. If anyone has a differing opinion I'm open to it.
Finally bought some tires and got them mounted.
I also bled the brakes and clutch with my new Motive power bleeder kit. I'm pretty amazed at the difference in pedal feel. Despite meticulously bench bleeding the master cylinder the old fashioned way, I found tons of bubbles came out of it when I did the same with the power bleeder. The clutch and brake pedals are rock solid now, which is nice.
I also slotted the motor mounts a touch so I could rotate the engine and get my header away from the steering box. It only had about 1/32" clearance, which had been driving me nuts.
I'm still waiting on getting my ECU/ PDM mount CNC'd so I can start the wiring.
But primary importance is figuring out how I'm going to handle the valve cover and block breather tubes.
VelvetHammer
Post by VelvetHammer » 26 Aug 2017 20:46
On the topic of "engine block and valve cover venting to a catch can", I was evaluating my existing setup and am baffled at a choice I made along the way.
My engine block vent tube currently has a -10 AN fitting welded on the end, which I'm just now noticing that the ID only 1/2", where as the OEM tube itself is 3/4". SO I managed to insert a restriction in there. Based on this chart I should really have at least a -12 AN fitting.
So there's that.
Since my engine compartment space is getting limited I think I'm going to go with two separate catch cans, one for the valve cover (which I'll mount where the OEM fusebox used to be) and second one for the engine block, mounted either on the driver side of the block itself, or the driver side frame rail. I'm curious about the pressures the containers will receive so I'll probably weld some bungs on there for a temporary pressure sensor mount
I went back to the Realm archives and found 10 or so articles on the topic I'll review to help understand proper catch can design and sizing. I already found a good tip buried in there regarding adding a spray bar. Looks like I should block off the cam's OEM oiling passage so I'm not over-oiling the upper half.
broke
Post by broke » 27 Aug 2017 04:04
Surprising to see the NZefi coil pack on the other side of the world! Engine bay looks great.
-McWicked
VelvetHammer
Post by VelvetHammer » 27 Aug 2017 13:40
broke wrote:Surprising to see the NZefi coil pack on the other side of the world! Engine bay looks great.
Yeah it's a nice bracket they make, took a bit to googling to find it!
The firewall and shock tower have a lot of holes in them from various configurations over the years. Once I get this new EFI system sorted out eventually I'll weld everything thing up and re-shoot the paint.
clean71
Post by clean71 » 17 Sep 2017 21:46
very clean 510 and love the color :D
1971 PL510 4DOOR AUTO
1969 PL510 WAGON 4SPD
1969 PL510 2DR 4SPD
Post by Three B's Racing » 18 Sep 2017 05:34
Saw no one answered this question so here it is. If you installed exactly like the picture shows, it's backwards.
VelvetHammer
Post by VelvetHammer » 18 Sep 2017 18:01
Ha! Well, it's in there backwards. Seemed to hold up just fine time last time, but will correct on the next inspection. Thanks!
VelvetHammer
Post by VelvetHammer » 15 Jan 2019 16:33
Man, it's been a while since I've posted anything.
I ended up buying a 3D printer (Creality CR-10 S4 400mmx400mm) and trying to teach myself how to learn CAD (hobby license of Fusion 360), so that's been taking up a lot of my time. The goal is to prototype parts and then get them fab'd or CNC'd as necessary.
I've been trying to figure out the elegant way of adding a cam sensor to the cylinder head and I think I've finally got the approach sorted out.
I've also been figuring out how to integrate the Motec harness with the OEM harness so I can use the OEM switches to operate the PDM-15. It was a nightmare but I think I got a handle on that as well. Long story short, don't trust the OEM schematics. My car had a few discrepancies.
Hope to post some details of the above soon
VelvetHammer
Post by VelvetHammer » 15 Jan 2019 16:34
clean71 wrote:
17 Sep 2017 21:46
Thanks!
