Post
by icehouse » 12 Apr 2017 23:40
duke
Post
by duke » 13 Apr 2017 09:46
Hey Jeff, that is looking very promising. Here are some pictures I have been sitting on for a while. These are of the rear end of an Australian 810 (?) Bluebird race car. I have always thought that this would be a cool way to set up the rear end of a 510 with minimal impact to the body. It looks very similar to what you are going for except the inner links go to a plate on the diff housing. I would think that this would give a little better camber control than what your initial design.
3468251386_eaf9e15586 by
Eldukerino, on Flickr
3468250706_22187edecd by
3468250526_6cf101c61c by
3468249488_cc2b98f5fd by
3467435889_02f6bd79fe by
Post
by icehouse » 13 Apr 2017 12:15
That is a cool design! Sam and I talked about a similar style as well. For a 1 off it would be totally doable. As for making a production run affordable to the average Datsun dude may be tough. We need to figure out our goal suspension travel. IE trying to get the toe change to zero but what kinda camber gain should we shoot for?
Duke have you ever tested the amount of suspension travel you use in the rear? Maybe Keith knows?
- Moderator
Post
by Byron510 » 13 Apr 2017 13:58
Duke - those are some very cool photos... gets the noodle going for sure.
Post
by bertvorgon » 14 Apr 2017 11:22
I can do a measurement next week for you. What it will be is the distance from the control arm to a body part seam. From this you can figure out the wheel travel. I touched this ONCE in all my years, never on the race tracks of any type.
It happened on one of our very fast drives (Duffy Lake) at about 115-120 MPH on a SEVERE bump, loading that side of the car..I heard and felt a "thump".
I would suggest that on rear bump we need about 2.5" minimum (1200# springs). I know I have 2.5 - 2.75 up front ( 300# springs).
That all being said, obviously my car is set up with lots of roll control for all the reasons (racey car). This helps with the camber and toe change, so as the travel goes up...so does the change of toe and camber..so that reverts to... WHAT are you doing with your car IMHO.
As I have talked about before, all this is moot of you run a crap tire, all the G-Whiz setup is NOT going to do any good if you run Sears Roadhandlers, what is the point.
So, given you are aiming for a true handling enthusiast, keeping camber negative and no rear toe out would be the aim.
Jeff, as you and I discussed, if the SHOCK becomes a factor of letting the car pull the wheel up if droop is too stiff, that just screws things up as you well now experienced.
Post
by icehouse » 12 Jun 2017 22:17
McShagger510
Post
by McShagger510 » 13 Jun 2017 23:19
- O_RLY-Quite.jpg (38.62 KiB) Viewed 1562 times
'91 Nissan truck
Post
by icehouse » 12 Oct 2017 12:35
Been a while since we updated. As per normal we've changed the design a few times, Sam is a picky bastard.... My response is usually "But I just want to drive my car!!!" Well here is what we have now... The version above didn't allow us to change the suspension characteristics like we wanted. Then we drew the design Duke posted. We felt it's weak design feature was around tire fitment. The arm ended up looking like a "Z" for tire clearance. So why we decided to use only the inner pivot which makes it more of an "A" arm. Plus we ditched the odd loaded heim joint for a weld in spherical bearing. Next we are going to run it through FEA and weld up a prototype. Who knows when we will be able to sell any.
- Moderator
Post
by 510rob » 12 Oct 2017 14:26
Doesn't Solidworks have a rusty Datsun sheetmetal surface option? That chromey one is too good!
Nice work Jeff & Sam (and don't forget the patience of both of your families!)
- Moderator
Post
by 510rob » 12 Oct 2017 14:27
icehouse wrote:"But I just want to drive my car!!!"
Oh easter eggs!
gooned
Post
by gooned » 12 Oct 2017 19:45
Skillz
Post
by bertvorgon » 13 Oct 2017 12:59
What I need to know...is how much is COKE kicking in for the advertising...?
datsuntech
Post
by datsuntech » 17 Oct 2017 00:17
Feel free to bitch slap me if you like, but if you're going to go to all the trouble of making a completely new control arm, why not make it so that you can use a bolt on hub like on many newer cars? This would effectively shorten the bearing area giving you more room for a longer shaft. My thought is if you are going to change this much wouldn't you want to go to CVs at the same time? The issue with CVs is always that the shafts are too long and need to be modified. This would give you more room for a longer shaft without widening the track width.
This of course is completely selfish because It's something I have wanted to do for some time but don't have the time to dedicate to this sort of project.
Brock
510wizard
Post
by 510wizard » 17 Oct 2017 07:41
datsuntech wrote:Feel free to bitch slap me if you like, but if you're going to go to all the trouble of making a completely new control arm, why not make it so that you can use a bolt on hub like on many newer cars? This would effectively shorten the bearing area giving you more room for a longer shaft. My thought is if you are going to change this much wouldn't you want to go to CVs at the same time? The issue with CVs is always that the shafts are too long and need to be modified. This would give you more room for a longer shaft without widening the track width.
Brock
And also no more bearing preload stuff using the "A,B,C " spacers(as I mentioned previously) and a new nut every time you need to disassemble. It would be a lot easier to build, just a plate to bolt the hub too, no machining a housing for the bearings and no adapters for the CV's.
JordanTr
Post
by JordanTr » 17 Oct 2017 12:45
I like s13/14/15 parts for the cartridge rear bearings. 4 and 5 lug availability.
