S14 with S15 block - SR20DET?
Roc1479
Post by Roc1479 » 08 Aug 2018 06:28
Guys,
New to all this, but came across someone selling an S14 top with S15 bottom SR20DET. Doesn't have any harnesses or ecu.
He says it turns over, but doesn't know too much about it because he got it from someone else.
Should I consider it for my 72 510 swap? Would it be very expensive to get the harnesses and ecu, mounts, crossmember?
What are some things to look for?
Thanks,
Rocky
2002 Nissan Xterra SC
1972 Datsun 510 4Dr
Re: S14 with S15 block - SR20DET?
Post by icehouse » 08 Aug 2018 08:12
S14 and S15 top is the same besides the cams. You can't tell the difference from the outside. I avoid motors other people have tore into unless it's a smoking deal.
The SR is my favorite swap.
Roc1479
Post by Roc1479 » 08 Aug 2018 08:26
I'm getting the motor for 200, not sure if I should jump because the guy who has it doesn't know much about it and I don't either.
1972 Datsun 510 4Dr
RonM
Post by RonM » 09 Aug 2018 00:22
Seriously at $200 you can't go wrong. Even if you had to rebuild it you'd be well ahead. That being said, if you're looking for a cheep short cut to an SR swap and don't have the money to see it through, that might be the most expensive $200 you ever spent. Do some research here and you'll see doing an SR swap is not a cheep undertaking.
Wiring Specialties sells a new modified upper harness for the 510 for around $550, or take your chances modifying a used harness off ebay for $180. There are also used OEM S14 SR20DET QU ECUs for $200 on ebay.
andrew.lori
Post by andrew.lori » 09 Aug 2018 06:21
I agree and copy what Ron said ....
1966 Sunbeam Tiger MK1A
1977 Datsun 200SX Sold :(
1973 Toyota Celica
Post by icehouse » 09 Aug 2018 11:32
Make sure it's not FWD. The price makes me think it is.
Post by Three B's Racing » 10 Aug 2018 04:44
icehouse wrote:
09 Aug 2018 11:32
S14-15 engines didn't come in FWD form so he's pretty safe there. $200 yeah grab it rebuild it, go carbs!!!
Beegee2
Post by Beegee2 » 10 Aug 2018 22:12
Maybe they don’t come in fwd in North America but they do in New Zealand and Australia and without doubt also in Japan.
They are different than the rwd engine though and are more difficult to fit so find out first which it is. They are known as
“NEO” here. They are useable with some adapting.
Post by Three B's Racing » 13 Aug 2018 07:20
Beegee2 wrote:
10 Aug 2018 22:12
Yes but were talking about a guy in NJ USA and highly unlikely it's a S14-15 FWD. Plus I'm sure he'd know enough to reconize the difference between fwd and rwd engines.
broke
Post by broke » 13 Aug 2018 15:47
Well S14 and S15 are RWD chassis so no danger of a FWD there... if you have a FWD block it's probably out of a U14/15 Bluebird or a P10/11 Primera or similar....
If it's got Neo VVL on the rocker cover then it's gonna be a VE anyway. If you can get one of those for $200 then buy it!
-McWicked
Post by icehouse » 14 Aug 2018 08:20
My guess is it's US SR out of a sentra. The seller is just calling it a S14 block with S15 head or whatever because it resembles one.
