Where to Stick the Stick? Dip stick ideas required LZ24 front sump
zKars
Post by zKars » 09 Feb 2019 07:55
Well the time has come to begin the rack and pinion conversion on my 69 510 with the LZ24 engine. First order of business that comes to mind is the dip stick.
Step 1 is to find a front sump oil pan. Done. I had a 510 "V2" L20b sitting in the corner with a front sump pan. Got it off and clean and it's matching pickup ready to go.
Step 2, the hard part, the dip stick. On the LZ24 block the dip stick hole is left side far back rear, which is really fun when you have the carbs and exhaust manifold on an L20 head blocking access. Now I have a working solution for that, (Lokar) but that's not going to work when I change to the front sump pan. What to do?
The LZ24 block has no "blank bosses" on the right side where a dip stick might go.
I'm thinking going in the right side of the oil pan itself with a welded in "S" tube and run the dipstick up behind the alternator and infront of the oil filter. Nice little space right there.
Anybody have any other bright ideas about a dipstick solution? Past experience?
zKars
Re: Where to Stick the Stick? Dip stick ideas required LZ24 front sump
Post by zKars » 09 Feb 2019 08:25
A wee bit of googling, and look what I found!
Video of a guy installing it and showing how it comes apart and works is found here
https://youtu.be/iX4gCgbU-as
Pair this up with a matching ford dipstick tube and dipstick (modified for length natch) and I think I may have a decent solution.
Rockauto has these parts for $7, $36 and $25 CAD for the flange, tube and dipstick respectively.
Whatcha y-all think?
Post by datzenmike » 09 Feb 2019 09:45
Interesting as I've built an LZ24 also but I think I'm calling it an L24B as there is already an L24 L6 out there and this is a nod to the L20 and the L20B. It's for my 710 and I have a spare L20B 710 oil pan so nothing changes there just the larger displacement block above it. Most car oil pans are a mid engine, slightly to the rear sump with room for the steering to clear at the back. Why not use a 510 oil pan and make the R&P fit it?
I was just going to check the oil when the engine was cold. :lol: But now will look at extending the dip stick tube and run a longer 'stick'. The one in our work van has to be a meter and a half long.
What head did you select? I ported and un-shrouded a U67 and drilled out the holes for the coolant cooled '79 intake and an L16 'cast iron header.'
zKars
Post by zKars » 09 Feb 2019 11:13
The rack and pinion is JBCoachwerks custom cross member and R&P solution. Oil pan has to accomodate it, not the other way around. I have not fitted anything yet, so I really don't know what pan or mods to the pan will be needed. JB clearly said that the rear pan won't work, well actually I think they said that a front sump pan will be needed. Dip stick has to move.
The engine I have is a Rebello built LZ24(b) block with an U67 L20B head. Tall sucker, just fits as is. Can't wait to make it fit with the new crossmember... Had to do a bit of cross member "thinning" and engine mount slotting and cross member to body spacing.... Ah the things we do to 'improve' our cars.
Post by datzenmike » 09 Feb 2019 16:00
The L20B is 20mm taller than the stock L16, and the Z24 is 20mm taller than the L20B. Lets hope so. I'm only going from an L20B to a Z series block so 20mm / 3/4".
If the L20B makes 95 hp (on a good day) then just the 20% displacement increase should net me close to 120 hp. Compression will be just above 9 so that should be even closer. What I do expect is gobs of torque from a stroke increase of over one cm.
