I'm tired of moving the big box of these harnesses around the garage. The prices shown are much lower than the last time I posted them, but if you still think they're too high, make me an offer. Time for this stuff to go!
The following are "engine room" harnesses (= the main harness, mostly under the hood but also extending through the firewall into the passenger compartment). I'm supplying parts numbers, vehicle details, and dates, where known. Where not listed, this information is unavailable.
Note: the first 4 harnesses are uncut, the 5th is repaired and perfectly serviceable, the last 2 have had one or two branches cut off. Prices reflect this. (Sorry, the pictures are scrambled-- I think they're all present if you keep scrolling down, but I can't figure out how to sequence them properly!)
All prices are in CAD and shipping from Edmonton, Alberta, is EXTRA.
# 1 uncut engine-room 24012-N0910 Aug 70 onward sedan auto trans incl 5 relays + fuse-box $120 CAD
#2 uncut engine-room 24012-N2705 Jan-Mar 72 sedan auto trans incl 6 relays $100 CAD
#3 uncut engine-room incl 5 relays $100 CAD
#4 uncut engine-room incl 2 relays $100 CAD
#5 repaired engine-room wires fixed, or taped together $80 CAD
#6 cut engine-room 24012-N2210 Apr-Jun 72 wagon manual trans incl 1 relay, but several cuts $60 CAD
#7 cut engine-room $40 CAD
Wiring harnesses-- "engine room" (main) (EDIT--lower prices)
- SteveEdmonton
- Harness 7.JPG (122.54 KiB) Viewed 2673 times
- Harness 6a.JPG (122.44 KiB) Viewed 2673 times
- Harness 5.JPG (120.5 KiB) Viewed 2673 times
- Harness 4.JPG (125.44 KiB) Viewed 2673 times
- Harness 3.JPG (127.13 KiB) Viewed 2673 times
- Harness 2.JPG (127.98 KiB) Viewed 2673 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Re: Wiring harnesses-- "engine room" (main)
Do any of your wiring harnesses include the Fuseable link?
- SteveEdmonton
That's a great question. Off hand, I'm not sure! I'm guessing the answer is YES, because they provide all of the wiring leading to the starter. But let me look into it and I'll let you know for sure.
Cheers, Steve
Cheers, Steve
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
Yes, I checked the best of the harnesses and the fusible link is definitely there.
Open to offers!
Open to offers!
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Can you post a photo or send me a photo of it so I can verify it looks correct? Thanks!
I would like to buy the engine compartment harness
and the
interior with switches included
what can you do for a package deal??
shipping should be easy per USPS flat rate
from 7.90 - 14.35 depending on which box is used
you can call me @ 408-310-2345
and the
- SteveEdmonton
Hey, thanks for your interest.
Is this the interior harness you're interested in-- the first one shown here, listed as #8? http://the510realm.com/viewtopic.php?f=10&t=31630 If that's what you're after, yes I still have it. And for sure let's make a combined deal.
On this page, which one of these "main" harnesses do you want? Let me know.
As for shipping, I'll need to use Canada Post, so the prices will be higher than what you mention. I'll get you a quote, though, so you know what you're looking at.
In order to do that, I'll need your name and full mailing address. Maybe we can shift to texting, for that.
Cheers;
Steve
Cheers;
Steve
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
