510 seat belt kit
yenpit
510 seat belt kit
Post by yenpit »
Just found this new seat belt kit listed! The upper loop mounting point DOES utilize the factory captive nut location in the headliner, HOWEVER, they designed it to DROP the actual seat belt loop down about 10 inches, which was my complaint about that upper mounting point.............it carried the seat belt up too high on my neck. That drop/extension remedies that uncomfortable position of the belt! We are ordering a kit now for a customer car, so will report back............
https://www.seatbeltplanet.com/i-304994 ... Fq%3D52218
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
paul97
Re: 510 seat belt kit
Post by paul97 »
Post pictures after they are installed please. I need a set for my car.
68 Wagon
Post by 68 Wagon »
AMEN! I would like these for my VG 510....way more secure than just my lap belts. Look forward to a follow up article with pics, please.
Baz
Post by Baz »
Check this link http://www.datsport.com/body-interior-r ... -belt.html
we ship many of these to the USA & Canada. most orders are due to referrals
Ask Troy Ermish he recommends our inertia reel belts.
The inertia reel is a new type & cover is now attached to the reel.
the difference between LH & RH belts is only the custom ADR approved mounting for extra seat room.
paul97
Post by paul97 »
Baz wrote: 10 Sep 2020 04:18 Check this link http://www.datsport.com/body-interior-r ... -belt.html
What is different about the 1968 510's? I saw your kit fits 1969-1972. I have a 1968 510 2 door.
MikeY
Post by MikeY »
I've installed a few datsport belts. One of the things I like is the receiver stalk. No more fiddling to find the loose lap belt receiver.
butters68
Post by butters68 »
i have the datsport belts in my car also, very nice set up.
paul97
Post by paul97 »
butters68 wrote: 10 Sep 2020 20:18 i have the datsport belts in my car also, very nice set up.
Isn't your car a 1968? It says on the web site that they won't fit.
butters68
Post by butters68 »
my old car was a 68 ,i sold that 3 years ago. i have a 72 now. :mrgreen:
paul97
Post by paul97 »
butters68 wrote: 11 Sep 2020 06:50 my old car was a 68 ,i sold that 3 years ago. i have a 72 now. :mrgreen: HPIM0403.jpg
Do you know what the difference in the seat belts is in the 1968 510 vs the 69 and up?
yenpit
Post by yenpit »
The 68-71 has the lower captive nuts for the seatbelts, but they screwed in "eyelets" & the seatbelts had a "hook" on that end. The eyelets do come out, so you can screw in the big bolts to anchor the later style seatbelts. I bet the upper captive nut is in the upper headliner rail, just not used for 68-71......?? I have a 69, will look!
Bottom line, I see no reason why the seatbeltplanet 3pt retractable kit won't fit the 68, as long as the upper captive nut is present.
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
zKars
Post by zKars »
yenpit wrote: 01 Sep 2020 09:38 Just found this new seat belt kit listed! The upper loop mounting point DOES utilize the factory captive nut location in the headliner, HOWEVER, they designed it to DROP the actual seat belt loop down about 10 inches, which was my complaint about that upper mounting point.............it carried the seat belt up too high on my neck. That drop/extension remedies that uncomfortable position of the belt! We are ordering a kit now for a customer car, so will report back............
Well I’m going to take credit for this. This is exactly what I had them build for me on three 510’s so far over the past few years. The set in my 69 has been in use for 5 years or more is great to use. The 9” drop loop from the shoulder belt Position is the key to get the shoulder belt sitting pretty on your chest over the shoulder.
I also did the “right” thing and added a second threaded embedded nut right behind/next to the lower outer stock position on the rocker sill, so the retractor reel and lap belt don’t share the same bolt. Apparently from their web site that’s a no-no. I think Datsport has something similar.
loungin112
Post by loungin112 »
I have an early edition of belts from someone...cant remember who. But they do not drop the top mounting point down at all, and yes, they cut across my neck irritatingly. When replacing, be sure they drop the top point down to avoid this. One day, this set will be moved to the back seat and a newer, better thought out, set will be installed.
Baz
Post by Baz »
yenpit wrote: 11 Sep 2020 14:24 The 68-71 has the lower captive nuts for the seatbelts, but they screwed in "eyelets" & the seatbelts had a "hook" on that end. The eyelets do come out, so you can screw in the big bolts to anchor the later style seatbelts. I bet the upper captive nut is in the upper headliner rail, just not used for 68-71......?? I have a 69, will look!
The problem is that the top rail anchorage needs a plate fitted with a threaded top hat bush.
This is on Australian delivered 68 models. Later models had to comply with ADRs, Australian Design Rules.
If the US model 68s have the rail anchorage I would appreciate confirmation.
Thank you.
yenpit
Post by yenpit »
Baz wrote: 13 Sep 2020 18:00
Thank you.
I don't have a 1968 MY to look at. Other issue is whoever might have a 68 MY, the headliner needs to be out of it to look for it! I'll message a buddy with a 1968 2dr race car.......no headliner!
TJ
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
