WTB: passenger side door lock
Looking for a passenger side door lock for 2 door 510. Don't need a working key as I can re-key it myself but body has to be in good condition with no cracks. My original lock mechanism is slotted open on top and has a number "3" on it if that matters.
Re: WTB: passenger side door lock
Images are not showing up but I posted on my dropbox to give you an idea of what the damaged factory unit looks like.
https://www.dropbox.com/s/ih6stzl2okbxx ... 9.jpg?dl=0
https://www.dropbox.com/s/0foxoo1swh50l ... 9.jpg?dl=0
Regards,
Owen
65 Sunbeam Tiger MkI
Owen
Thanks for the info. I should have mentioned I'm looking for an OEM unit. I have an aftermarket one but the swing arm has alot of play and not sure if its re keyable.Has anyone taken apart an aftermarket unit?ostaylor wrote: ↑19 Mar 2023 08:25 ZCar depot has them...
https://zcardepot.com/collections/inter ... 3573843057
I almost certain they can be rekeyed. I know I plan on rekeying mine along with the ignition and trunk.
Regards,
Owen
Owen
Found one on Amazon that has the return spring and matches more of the factory design . I just need to swap out for the original arms. I ordered a set and will try to rekey these.
https://www.amazon.com/NewYall-Front-Dr ... merReviews
I will have a good right side door lock, but no key. PM if interested!
TJ
TJ
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
Thanks TJ. I will attempt to piece together the parts I am receiving. Maybe you can tell me (my posted links) if the original locks from my car is actually a part from a newer model 78+ Datsun 510 or Nissan Truck 85+ including the D21 Hardbody? I researched most OEM locks don't have a return spring or open casing that shows the lock wafers.
I agree that that lock is later, cuz of external spring & the yellow plastic clip for the rod.
PM response sent!
PM response sent!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
