replacing mustache bushings
Oh yeah and yours has an R because your bushings are red. I bought the black ones because I didn't want them to stand out. So thats where the letter is different, but I'm not sure about the numbers being different, unless it's just a diferent bar code because of the different color. I can't believe noone has had this problem yet.
Corky Bell, Maximum Boost
-defdes
-defdes
I called E.S. today. That is the differance in both numbers, just the color. I sent them some pics too to try and figure out what was wrong, I'd be curious to herar what others have done. I have only done one of them so far, but I used the outermost sleeve from the old bushing, made another steel one from a piece of steel tube that the E.S. bushing slides tightly into, then pressed them into the mustache bar using the vice. As long as the relationship is the same, and its tight in there, anyone see any problem with it. I guess that the metal ring of the carrier on a meteal sleeve against another metal sleeve might not be the best scenario, but its a very positive fit, and with the big washers on top and bottom, the sleeves cant go anywhere...
Damn, I just tried tried to post too. Maybe I'll go back and delete some of my earlier pics and see if that works...ahh, it did.
Did you ever hear back ES?
I put my bushings in today. Was like butter. Took about 45 minutes. Just burned the old rubber out. popped the two piece retainer out. Lubed them up and in they went. Pinched them in with a vice. There is definetly something wrong with your. Either duke was right and you got the right box/wrong bushings, or you have a different/custom mustachio bar. The OD of the round metal end of the bar is 50 mm, and the od of the larger end of each bushing is 50 mm.
It seems like your method worked, BUT the point is for the fit to be VERY firm and stiff, and with an original bar and correct bushings it is. So I just hope your custom one is fit tight. I would be very interested in hearing what the od of the wide end of your bushings are. My guess is that they are about 46mm, or the bar has an OD of about 54mm. If you check this out let me know!!
Hope this helps!!
Hope this helps!!
-defdes
-defdes
Hey defdes!
I have some news on this! heirfaus was over yesterday. I saw his mustache bar and the 7.1104 bushings fit it perfectly. They do not fit in either of my mustache bars. Mine are exactly like yours. I searched the bluebird list archives and found someone saying there are two different 510 mustache bars. Early ones take the 7.1104 bushings. Later ones (like you and I have) are said to work with a Z car bushing set 7.1102. I have one set of both bushings. I burned out the rubber and left the shells in the bar. Turns out the Z car bushing (7.1102) fits on the wider side and the 510 (7.1104) fits the smaller (rolled in) side of the shell.
Anyone ever seen this before? I'm thinking of just running one of each and splitting the cost with someone else who needs them (defdes??)
Input appreciated.
Also, which side is up on the mustache bar - the straight one or the other side?
Input appreciated.
'70 510 2 door
chopped '69 521
chopped '69 521
Kieth what year is your bar from. I have no idea what mine is from, but it looks just like yours and the bushings slide in.
Incase you missed the pic look at page one it has bothe styles. Bertvorgon has one style, same as I do. defdes has the other, same as Wurker.
-defdes
-defdes
My bar is definately from my 73" chassis, as far as I can remember. The stock rubber bushings are still in there, we just made those special jam washer peices, to totally lock up the subframe, so it does not move.
While I think of it, if the diff is out, this is a good time to check and adjust the driveshaft angularity. If you have had no vibration problems, then leave all your diff washers where they were. If you have had vibration issues, measure the tailshaft angle on the transmission, then, when you put the diff back in, you want the pinion to be within 1/2 to 1 degree of what the transmission was. It's worth the effort to do that, specially if you actually do some high speed driving. Adjust, or make some similar washers to get you in the ball park. Double check after you tighten everything up. When we all do these motor/tranny/transmission mount changes, things can get out of whack pretty easily. Nothing like having as smooth a power train as possible, when driveshaft speeds are up in the 7,000-8,000 RPM range, let alone a nice freeway cruise speed.
I put the dogleg in and I later swapped to R180. I just put the same spacers in that I had in with the R-180. I don't think I have any vibration but........
how do I go about checking the difference in angles?
-defdes
-defdes
Ok, take your protractor, and put it on the tail shaft of the transmission, so that is on the outer edge of where the yoke slides in. This will give you an angle, record that. Then, put your protractor on the pinion where the flange is mounted for the driveshaft to bolt onto, this will give you an angle. You want them to be within 1/2 to 1 degree of each other. This is where your either adjust the diff, spacers/washers, or see what you can do with the trans mount. Not sure if I made that clear, let me know.
