Weatherstrip "ADHESIVE" Removal
bueiz
Post by bueiz »
Hey guys....
I was wondering if any of you out there had any tips or tricks on how to remove the adhesive residue left behind after removed weatherstripping. I'm replacing the Windshield on the wagon and after removing the old "windscreen gasket" I was left with a nice bit of crud.
Any inputs would be greatly appreciated! Thanks!
Jo ("hoe")
Re: Weatherstrip "ADHESIVE" Removal
Post by defdes »
I would say Acetone, assuming it's in areas that wont be seen. That and maybe some Scotchbrite.
Dimebag
Post by Dimebag »
I haven't tried this on weather stripping glue residue, BUT... I used wheel/rim cleaner (Castrol is my favorite) to very effectively remove an old radio station sticker from the inside of my rear window without destroying the defrost lines. I used a sponge to apply, let it soak for a few minutes, and it just wiped right off. I would expect it to be safe with paint, but don't take my word for it.
super clean.jpg (20.27 KiB) Viewed 5265 times
John Thiessen
72 Wagon
Post by okayfine »
Dimebag wrote:I haven't tried this on weather stripping glue residue, BUT... I used wheel/rim cleaner (Castrol is my favorite) to very effectively remove an old radio station sticker from the inside of my rear window without destroying the defrost lines.
WD40 would also work to remove sticky adhesive. The 3M weatherstrip adhesive tends to dry very hard, and it's not really sticky. 3M makes mention of just using general-purpose adhesive remover, but I'd do a test with any product before using it on the car.
hang_510
Post by hang_510 »
hoseA, good to hear your still out there :mrgreen:
plastic scraper and IsoPropyl Alcohol (dont drink it!) same idea as acetone
Dimebag
Post by Dimebag »
okayfine wrote:WD40 would also work to remove sticky adhesive.
you know, I tried WD-40 on that sticker because I had heard it would work, but I had no luck with it. I had also tried a citrus-based so-called adhesive remover called "Goo Gone", but that didn't work either.
John Thiessen
72 Wagon
yenpit
Post by yenpit »
3M "General Purpose Adhesive Cleaner" part #08984 for a 1qt can, available at any good automotive body & paint supply store.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
Post by okayfine »
Dimebag wrote:you know, I tried WD-40 on that sticker because I had heard it would work, but I had no luck with it. I had also tried a citrus-based so-called adhesive remover called "Goo Gone", but that didn't work either.
Wow. That's some space-age adhesive. WD-40 usually works for me, spray some on a rag also makes it easy to clean the grime off engine bay wiring so I can see the wire colors. What WD-40 doesn't remove, the citrus stuff does. Good thing, too, 'cause they've probably outlawed your solution here in CA.
