Has anyone used theese rims on a 510 with 280zx struts/brakes in front and 200sx discs in back. I used to own a 97 and i like the rims. I read on a site that theese might work on the 510. Any Info would be great. I found the info on this site http://kmhafer.datsun510.com/wheelchart.htm
Thanks
Mike G
93-97 nissan altima rims
1972 4dr 510 (Turbo KA24E build in progress)
Re: 93-97 nissan altima rims
if you post the size...
we could help you.
most of us probably haven't owned one like yourself.
we could help you.
richard norrish
I have no clue what the offset is but the rim size is 15x6 although Im sure that does not help much. according to the website i found the info on it says BS = 135mm or 5.31" OS = +46mm 195/50-15 205/50-15 If that helps at all.
Thanks
Mike G
Thanks
Mike G
If the offset is 46mm, as indicated, then they can be used on a 510 but you will need a pretty thick spacer, which will also necessitate longer studs or the spacers that have integral studs.
Compare to the 15x6 280ZX Turbo rims, which are a +12 offset and will fit your ZX front struts. I ran them with a 195/50.
Cool.. thanks for the info everyone I appreciate it.
Mike G
Mike G
