Ecotec 510
510tdi
Re: Ecotec 510
Post by 510tdi » 13 Dec 2016 22:44
Would those mpg numbers be even higher with a stock (150ish hp) Ecotec? What is it about the design of the Ecotec that allows it to make power so much more efficiently than anything in the Nissan "catalogue"?
ecotec510
Re: Ecotec 510
Post by ecotec510 » 17 Dec 2016 09:16
510tdi wrote:Would those mpg numbers be even higher with a stock (150ish hp) Ecotec? What is it about the design of the Ecotec that allows it to make power so much more efficiently than anything in the Nissan "catalogue"?
No, I think most of the mpg gains come from the VVT variable valve timing. There's oil actuated cam gears on both camshafts, that adjust on the fly for max power under wot, and also for max mpg under light throttle. This is also the secret to the higher hp/L than similar non vvt engines.
www.machinedspeed.com
ecotec510
Re: Ecotec 510
Post by ecotec510 » 17 Dec 2016 09:27
Teaser shot of newest mod. 2016 STI rear hub assemblies. Design and machining of an upright to mount the bolt on hub bearing to my trailing arms in the works. My original frankenstein rear trailing arms have worked well, but I think I can do better and trim weight with these modular bearings.
IMG_20161216_094608 (Small).jpg (95.5 KiB) Viewed 2333 times
ecotec510
Re: Ecotec 510
Post by ecotec510 » 09 Jan 2017 16:46
New rear knuckles are engineered, designed, machined and assembled on the car. 7050 aluminum. Dropped 7 lbs per side of unsprung weight over the old cast iron Subaru pieces. Revised the lower shock mount location, and made new upper shock mounts to get everything to clear.
P1090571 (Small).JPG (86.77 KiB) Viewed 2273 times
P1090573 (Small).JPG (86.54 KiB) Viewed 2273 times
P1010547 (Small).JPG (86.73 KiB) Viewed 2273 times
Re: Ecotec 510
Post by RONSLYCHUK » 09 Jan 2017 20:20
Very nice looking work.
Re: Ecotec 510
Post by okayfine » 10 Jan 2017 06:07
*cough* Featured Builds */cough*
spriso
Re: Ecotec 510
Post by spriso » 10 Jan 2017 12:40
Love, love, love the work on the rear uprights-- well done!
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
ecotec510
Re: Ecotec 510
Post by ecotec510 » 10 Jan 2017 19:41
Thanks guys. Wow, Featured build! These uprights have been hiding in my head for a few years, finally being able to make them a reality is a great thing. Car is now aligned and brakes are bled. Road testing tomorrow, I'll see if the unsprung weight loss is noticable.
ecotec510
Re: Ecotec 510
Post by ecotec510 » 15 Jan 2017 15:09
Perfected the flaws in my prototype R180 diff cover and machined a few more. I'll list these up in the classifieds soon. Machined from 7050 aircraft aluminum. They'll ship with a gasket,vent, -8 ORB plugs, and new bolts. Very stiff internal structure should add a little extra rigidity to the diff case and hold 1/3 more oil. Engraved one with '510' from Julian's vector emblem art file, turned out looking slick.
P1150575 (Small).JPG (101.13 KiB) Viewed 2130 times
P1150584 (Small).JPG (106.35 KiB) Viewed 2130 times
P1150579 (Small).JPG (96.49 KiB) Viewed 2130 times
P1150581 (Small).JPG (71.75 KiB) Viewed 2130 times
WxMan
Re: Ecotec 510
Post by WxMan » 15 Jan 2017 15:32
Wow! Those are gorgeous. Love the 510 detail.
Russell
Re: Ecotec 510
Post by Byron510 » 15 Jan 2017 17:28
And the cost and availability is.....?
Re: Ecotec 510
Post by bertvorgon » 15 Jan 2017 19:34
I second the motion.....sign me up....
ecotec510
Re: Ecotec 510
Post by ecotec510 » 15 Jan 2017 20:38
Thanks for the interest guys! I'm thinking around $550. These 3 are ready to sell as soon as I get the plugs in this week. They will include everything needed to bolt on. I can make more no problem. I can also engrave 510 on the others if that's desired. They'd look awesome hard anodized but I'd have to have quite a few sold to make that affordable. So they'll be sold in bare machined finish, but 7050 is pretty tough stuff.
ecotec510
Re: Ecotec 510
Post by ecotec510 » 21 Jan 2017 17:05
Played around today and machined up a 510 replacement horn button.
P1210592 (Small).JPG (66.31 KiB) Viewed 2011 times
P1210596 (Small).JPG (80.52 KiB) Viewed 2011 times
Steinny
Re: Ecotec 510
Post by Steinny » 04 Mar 2017 11:18
Just read through this build. Amazing job man. One quick question, do you have any pictures of what you did to the rear upper shock mount? Looks like your coilover has a spherical bearing on the top hat as well and was curious. Keep up the great work!
