I have a set of these rims and would like to run them on my 4-door 510. I have read the wheel + tire faq written by Kurt Hafer. If I understand correctly I could run these wheels with 195/60/R14 Azenis without throwing the speedo/odometer reading out of wack (at least not by much). Is this right?
I am planning on doing a 280zx struts with disc conversion on the front at some point but may run the stock 510 setup for now.
14x6 wheel with +12 offset
280zx wheels
280zx wheels
'67 1600 Roadster
'68 4-door 510
'68 4-door 510
Re: 280zx wheels
If that is going to be the same overall diameter as a stock 510 tire, then yes. You can plug in the numbers to Dave Lum's handy-dandy gearing calculations spreadsheet and see for yourself:muck wrote:If I understand correctly I could run these wheels with 195/60/R14 Azenis without throwing the speedo/odometer reading out of wack (at least not by much). Is this right?
http://www.datsuns.com/Tech/tech_gearing.htm
specifically here:
http://www.datsuns.com/ftp/Calculations2.xls
To be completely accurate you'd have to find the actual diameter of the Azenis. As with actual width versus the sidewall markings (195, 205, etc.), they do vary.
Re: 280zx wheels
Thanks for the link Julian.
If I plugged the correct numbers in the difference is -0.3%. Pretty much bang on.
Based on a 165/78/13 stock 510 tire. Can anyone confirm this is the right stock size for my car.
'67 1600 Roadster
'68 4-door 510
'68 4-door 510
Re: 280zx wheels
Owner's manual says the original tire was a 5.60-13-4....whatever that is
Re: 280zx wheels
had great success with either 185 60 14 or 195 60 14. you should be fine with either!
1972 Datsun 510 Wagon 5spd - SR20DET, 20G, VS-XX
1972 Datsun 510 Sedan 5spd - L18E, twin SU, Riversides
Re: 280zx wheels
I am running those wheels on one of my dimes with the Falken Azenis RT615 tires 195-60-14 and the speedo is off about 2-3 miles per hour.
Enjoy The Ride!
David
David
Re: 280zx wheels
Good to know. Think I can live with that.qwik510 wrote:I am running those wheels on one of my dimes with the Falken Azenis RT615 tires 195-60-14 and the speedo is off about 2-3 miles per hour.
'67 1600 Roadster
'68 4-door 510
'68 4-door 510
