Black and Blue '68s
Mattndew76
Re: Black and Blue '68s
Post by Mattndew76 » 20 Nov 2014 17:37
Right
greenthumb
Post by greenthumb » 20 Nov 2014 17:38
Right
cool project Joel- I am part of that demographic :lol:
Post by James » 20 Nov 2014 18:12
Right
gooned
Post by gooned » 20 Nov 2014 19:30
greenthumb wrote:Right
Just looked this up :lol: Right is right, I need some for the M...
Mattndew76
Post by Mattndew76 » 27 Dec 2014 16:50
Joel tell us a Christmas story.
Did you do more cool stuff to the car?
Post by two_68_510s » 26 Jan 2015 13:58
No great updates BUT I do have some stickers.
$3.00 + $.50 postage = $3.50 email me at: joel@armoredmobility.com
Post by two_68_510s » 07 Feb 2015 23:01
Got about half the build (3 coats high solids urethane topcoat, 3 to go) of the thickness of film I need on the finish before I cut and polish, ebony is very porous with "cracks" in the surface to fill.
Post by two_68_510s » 14 May 2015 18:06
I have had many side marker lights through the years for the '68 that had the bolt support bracket on the back of the lens, rusted through or almost through like this:
So I decided it was a shame. I found some paper thin stainless sheet:
Then I cut a couple little of patches for inside the bracket
Using some aircraft frame type epoxy, stuck them inside
Then added the shell
Post by James » 14 May 2015 18:28
Nice!
RonM
Post by RonM » 14 May 2015 19:25
Joel my friend, you must have an incredibly high tolerance for pain, because you've set new levels for the definition of the word painstaking on this build. As always, my hat is off.
Post by two_68_510s » 17 Jun 2015 16:20
Just got my EDIS trigger wheel sensor bracket from the machine shop:
rendering
pickup bracket.JPG (27.58 KiB) Viewed 1683 times
Post by two_68_510s » 04 Aug 2015 20:09
Made up a divider/reflector for the early Euro front turn signal assembly. Required some "tooling". I use the word loosely!;)
Post by 510rob » 04 Aug 2015 20:11
so much win!
Post by Byron510 » 04 Aug 2015 22:27
You know, you have to be happy with the result.
Great job.
Post by two_68_510s » 04 Aug 2015 23:05
thanks guys
