Spriso's SR20DET Bluebird Coupe Project
cambo
Re: Spriso's SR20DET Bluebird Coupe Project
Post by cambo » 03 Dec 2019 05:33
Nice work as always. Were the wagon frame rails TIG brazed on the bottom of the car?
spriso
Post by spriso » 03 Dec 2019 08:45
Yes-- the wagon frame rails were plug welded thru the floor on the top side, and stitch welded with silicone bronze on the bottom side. Eventually, the entire underside of the car will be stitch welded on the seams with the TIG as well.
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Button
Post by Button » 03 Dec 2019 17:37
Beautiful build - keep up the great work !!!
Post by RONSLYCHUK » 03 Dec 2019 18:23
You sir are a true artist on your metalwork!
spriso
Post by spriso » 08 Dec 2019 10:44
More progress yesterday-- I got the driver's side dog leg welded in and decided it was time to do something a little more fun than rust repair.
The driver's door needs to have the window frame installed, which meant that it needed to be fitted to the body so I could determine the correct gaps so it fits in the frame properly, as well as having the weather strip fit correctly.
First the door shell was fitted with some new hinges, and then to make sure that I had the gaps correct, I pulled a NOS fender out of stock and fitted that as well:
Of course, there was lots of adjusting to get the gaps right and having everything sit correctly. Then I decided I should also check the passenger side sheet metal to see how that fit (and to have a way to confirm the door fitment).
About 20-years ago, I was very fortunate to find a NOS Bluebird Coupe door which has been patiently waiting for this day. I pulled it out of inventory, finally having a reason to fit it to the car:
I put some NOS door hinges on the door and did a first test fit:
Needs a little more adjustment, but as a first fitment, it looks promising. I also added a NOS front fender for the passenger side which will need to have the marker hole welded up and the hole drilled for the fender mirror too:
Nothing beats the crisp, sharp lines of new sheet metal...
More soon,
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Post by RMS » 08 Dec 2019 20:43
:shock:
miguel sss
Post by miguel sss » 23 Jan 2020 10:46
Very good... ;-)
