rebuilding half-shafts?
Chadsinto510s
Re: rebuilding half-shafts?
Post by Chadsinto510s » 10 Feb 2012 10:16
PM sent Steve.
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:20
Disassembled one half-shaft today. Here are some pics. Eventually you'll see the problem I uncovered along the way.
IMG_5805 web.jpg (254.05 KiB) Viewed 1753 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:21
IMG_5807 web.jpg (243.62 KiB) Viewed 1752 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:26
IMG_5810 web.jpg (33.8 KiB) Viewed 1752 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:32
Another pic-- ready to come apart.
IMG_5815 web.jpg (44.18 KiB) Viewed 1751 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:33
The balls & spacers-- note brownish colour of some! :(
IMG_5818 web.jpg (41.15 KiB) Viewed 1747 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:36
Trying to keep the 4 sets of balls-and-spacers separate from each other, and associated with the correct races in the shaft. A filed notch on the end of the shaft is the key (it matches a notch filed on the axle tube, to keep them properly aligned as well).
IMG_5819 web.jpg (43.91 KiB) Viewed 1747 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:38
Bad news though: the notchiness I felt while telescoping the shaft (on the bench) is due to these grooves/wear marks in the races. The brownish staining is obviously rust... yet these look simply like wear marks to me? In any case though, this is not good.
IMG_5822 web.jpg (30.19 KiB) Viewed 1746 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:40
Another set of wear-marks in another of the races. Two of the four races are like this.
IMG_5823 web.jpg (31.77 KiB) Viewed 1746 times
'71 4-door
'74 MGB-GT
'04 Miata
510wizard
Post by 510wizard » 11 Feb 2012 18:40
SteveEdmonton wrote:
There is a mention in the body and chassis manual about replacing that o-ring.
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:41
Finally, the matching wear-marks in the outer part of the axle.
IMG_5829 wear marks web.jpg (27.54 KiB) Viewed 1746 times
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 11 Feb 2012 18:45
So, how serious is this wear in the races? As noted, I became aware of the problem only when telescoping the axle by hand on the bench. Didn't notice any problem while driving. Clean, grease, reassemble, drive? Or-- ?
The note about replacing that o-ring is helpful. I'll definitely want to do that, yeah.
'71 4-door
'74 MGB-GT
'04 Miata
proflex
Post by proflex » 11 Feb 2012 18:57
I think all you can do is grease it up good and re assemble.
Chad.
Post by goichi1 » 11 Feb 2012 22:06
I don't think it would be an issue either, when they are on the car they just slide in and out a few inches if that....re-grease and put them back together....just does the old "in and out" :shock:
510wizard
Post by 510wizard » 12 Feb 2012 06:51
Do you want me to scan the page from the manual? It shows how to check the specs with a dial indicator to see if it's worn out and not usable.
