Gordy's ecotec 510
Sleepys-14
Re: Gordy's ecotec 510
Post by Sleepys-14 » 07 Mar 2017 06:28
funwithmonkeys wrote:There are a couple of issues. I just got my struts shortened and before I did the swaybar was making contact with the crossmember at full compression about the same time I hit the bump stops.
At the same time it is almost coming in contact with the T/C rods.
I really like the Futofab sway bar but I am for sure going to need something different. If I just lower the bar the center section of it will be more than 3" below my crossmember and the lowest point on the car by a lot. I am going to remove it later this week and see if I can flip it and make it work but I think it would mean standoffs that are approximately 4" and would put the mounts of the bar lower than my crossmember. Also at the lowest point of the car. I am pretty sure getting a custom one made will be the way to go.
You could first start by shortening the endlinks to gain some clearance at the subframe. Also if you are not running roll center spacers, that will help the whole situation. As far as the tension rod touching the swaybar, you might want to lower the tension rod pickup. Not only will that reduce the anti-dive in the front suspension, but it will also give you the clearance you need for the tension rod.
Post by icehouse » 07 Mar 2017 23:08
funwithmonkeys wrote:Image
I had the same issue. I remounted my TC rod under the LCA with an aluminum spacer about an inch thick. Now my suspension bottoms out before it hits. Just barely though. I have the super tall bump steer spacers as well.
Post by funwithmonkeys » 08 Mar 2017 15:56
I never thought of getting the tension rod front mounting lowered. I am running 1" bump steer spacers. Shortening the end links just gets me closer to the tension rods.I am going to put the struts on tomorrow and see exactly what I need for it to work. Bigger bump steer spacers would help but they would probably need to be 2". I am thinking of going to a modular sway bar with splines for the arms to attach. I could build just what I need.
Post by Byron510 » 08 Mar 2017 16:32
You'll see that I had to drill an access hole right though my stanchion for mounting it in the stock 510 sway bar mount holes. Pics say it all. The Mac Tilton ones were not built like this, and it was nearly impossible to get the bolts on. Not to mention that those said bolts were too short for proper engagement in the captive nut. So, being a machinist I had to make it better - which I think I succeeded in doing.
For your possible strait bar set up, you'll likely need to build something like this to clear the oil pan. At least i did the hard work for you :-) The design is done.
Stanchion 3 DSCN4576 (Medium).JPG (96.25 KiB) Viewed 639 times
Stanchion DSCN4576 (Medium).JPG (52.5 KiB) Viewed 639 times
Post by funwithmonkeys » 08 Mar 2017 16:37
If you feel like making another set Byron let me know.
Post by bertvorgon » 08 Mar 2017 17:58
For what it is worth, this is how I did mine, and I did move the T/C mounting point also.
Custom bent sway bar too.
IMG_7973 (Large).JPG (268.95 KiB) Viewed 633 times
IMG_7972 (Large).JPG (329.38 KiB) Viewed 633 times
Post by funwithmonkeys » 08 Mar 2017 18:01
Are your mounting points moved up Keith? I think that moving them is a bit beyond my level of skill.
