Project Ghetto Fabulous!!.....the Crazy Corona..........
Re: Project Ghetto Fabulous!!.....the Crazy Corona..........
Post by goichi1 » 16 Jun 2013 22:49
Finished installing the radiator and then worked on the exhaust, got that all hooked up and welded to the stock exhaust pipe, even blasted and painted the manifold too...
Post by goichi1 » 16 Jun 2013 22:51
The more I look at the crappy engine bay, the more I want to paint it, but I keep telling myself this is just a low budget swap and go.....
Post by James » 17 Jun 2013 07:12
butters68
Post by butters68 » 17 Jun 2013 19:02
just ghetto spray bomb it mang. :wink:
Post by goichi1 » 17 Jun 2013 20:29
I've thought about it!! but cant see myself doing that!!
Post by goichi1 » 20 Jun 2013 23:31
Got a little more done on the crazy corona.....intake cleaned up and started to put it back together on the car, looks like I can keep the windshield washer bottle!!! I'm so excited!!......but not sure if it works or not.
510wizard
Post by 510wizard » 21 Jun 2013 06:33
The relay on the left side fender is just like the horn relay on the Land Cruiser. Looks like the brake master is going to need some work. :wink:
Post by goichi1 » 21 Jun 2013 08:51
...Oh, there's a lot more than just the brake master that needs some work!! I'll probably just get a new one, they are not that expensive. that is if I have brake problems! this is low budget remember!
Trophy24
Post by Trophy24 » 07 Jul 2013 21:11
Had to look this one up after talking to you Saturday. I will be following for sure. I would totally drive this car!
Post by goichi1 » 08 Jul 2013 07:13
Trophy24 wrote:Had to look this one up after talking to you Saturday. I will be following for sure. I would totally drive this car!
yea! It was really nice meeting you the other day! I had hoped to work on it last night but was busy with house stuff so no progress on the wiring, I should be able to get to it tonight. I want this thing on the road.
Post by goichi1 » 17 Sep 2013 22:35
Tonight a friend came over and blasted some BMW head covers, so I figured it was a good time to blast the Yota cover and get it ready to powder coat. I shaved all the edge flashing off and really cleaned it up, also cut down a tall mounting bung on the back corner. I plan on using some wrinkle black powder.
510wizard
Post by 510wizard » 18 Sep 2013 07:09
Are you doing the power coat yourself ? I am thinking about getting a set up, but I don't know how much I would use it and how good of job can be done at home compared to a pro shop.
Post by goichi1 » 19 Sep 2013 08:17
yes, I will do it at home. I have had excellent results in the past on the coupe. I have a little Craftsman powder coat gun, it doesn't hold much powder but it seems to work ok. The key to a good end result is in the prep work, it has to be super clean, I blast, cook, wipe with acetone, cook again, then apply the powder to a hot piece then cook for 20 min. less cook time and lower temp for clear. I did the SR head cover and diff cover on the coupe and a bunch of the small brackets and junk....out of everything I only had one thing that came out terrible, but that's because I didn't get all the plating off...
From my coupe build thread, Platinum color powder with low temp clear powder over the platinum. I thought it was very nice for the first bigger piece.
510wizard
Post by 510wizard » 19 Sep 2013 08:36
That came out great! I am going to look into a powder coat setup now. Where do you get your powder from?
Post by goichi1 » 19 Sep 2013 14:41
I got it from Eastwood. I would like to get a new gun. I have been looking around but gotta stop buying stuff so it will have to wait and the one I have will have to do for now.
