68 CDN going to be all like JDM yo!
Re: 68 CDN going to be all like JDM yo!
Postby RMS » 25 Apr 2017 19:02
looks ok but it would have been nice if they did not cut the provisions for the seat belts and gas pedal as I imagine the placement of these items differ on year and whether its a 091, 092, 094, 095, 194, or the 195 auto estate ?
back to the hunt for the correct front and rear grab handle that would work on the provisions along the roof line. I explored the 240 door grab on 6 inchesImage
then I scored a stack of factory parts catalogs Image
could nissan have had the intention of running a Cedric handle on the pl510 ?
model 31 front ass'y-strap assist 96701-34200 and 96750-322201 hanger-coat
or the later p130 straps
what year is Merlin's Cedric ?
Postby RMS » 01 May 2017 22:14
Got my newly refinished back seat from classic threads over the weekend. ImageImage
the shake down
Postby RMS » 15 Jul 2017 23:08
continued from Butters68 build: ImageImageImageImageImage
it wasn't long after we set off to the gas station that I found my self on a hoist and production @ kall ground to a halt.
ya see ...... after a quick valve job on Butters we were itching to hit the road. I ran through the list and put some foam tape on the top of the carb. out the gate and down river we went. seventy came very fast even though I was barfing black clouds when tromped. an easy sixty on the 90s to 5rd. vickers and five I ease past the stop line with vigor and into the pumps just down the road. gas door open, card in hand and a guy in a white e86 pulls up in a flurry. with a Nissan lug nut between two fingers. :oops:
Postby two_68_510s » 16 Jul 2017 11:43
Oops, any damage to the wheel?
The 68 rear end is clean looking. I am prejudice, of course.
butters68
Postby butters68 » 16 Jul 2017 19:33
it was a two 68 510 saturday. :mrgreen:
McShagger510
Postby McShagger510 » 16 Jul 2017 22:50
Looks great! Lovin' the hoist shots!! :mrgreen:
'91 Nissan truck
Heinrich
Postby Heinrich » 16 Jul 2017 23:04
beautiful shot.
Postby RMS » 18 Jul 2017 10:27
thanks guys. the rim actually looks a bit better, all the holes look round now.
the only bad thing that happened is I lost my air correction kit for the dcoe's. anyone have some jets ?
Postby two_68_510s » 18 Jul 2017 11:28
RMS wrote:thanks guys. the rim actually looks a bit better, all the holes look round now.
Good one :lol: :lol: :lol:
Postby RMS » 26 Jul 2017 22:36
broke down and drilled the car for the rear 68 garnish. its 0.5mm off :x I will need to enlarge the mounting holes to get it centered.
I also grabbed a costco group 24 AGM
Postby RMS » 09 Aug 2017 12:45
very happy that the provision made for the o2 sensor worked out.
the 3 piece front carpet kit makes service so much easier.
now only if I could find a couple mirrors like this:
Postby RMS » 10 Aug 2017 09:25
finished up installation of the af gauge. but im thinking : if I can see it blowing black its probably not in the range. so do I risk fouling the sensor or just go down a size before I fire it up with the o2 sensor installed ?
Postby RMS » 11 Aug 2017 09:16
well I fired her up... I wasn't as far off as I thought. once the motor was at temp the af gauge was bouncing between 10 and 12. with much fiddling I got it wavering between 13 and 14. touchy idle screws... working between say one hour on the clock. with the idle close to 14.7 I slowly brought up the rpms to 2000 and the gauge read 16. fully pined to 18 on deceleration. running 50f9 and 130 main.
Postby RMS » 22 Aug 2017 09:41
too many paint fumes ...... found that box of jets :roll:
the jetting is good throughout the range except between 2900 and 3600 were under light load it falls to 10to 1 @ wot she's pulling 13.5.
next smaller main and smaller air correction ?
I tried swapping when on the road ........ pulled in to a gas station to swap the jets and as I was installing the holder the jet fell out and into the bottom of the carb :shock: luckily two stir sticks worked to extract the offending jet.
Return to “Featured Project Builds”
