Re: Nissan Bluebird Coupe (JCCA Race Car)
Posted: 17 Nov 2018 10:35
Did you do any dyno pulls before and after? Curious to how (if any) restrictive the mesh are vs none or filters.
As it's coming to the end of the year, my employer are telling me to take leave, or lose it (we get a good amount over here in the UK) so I've had a couple day off this week to work on the car. Problem is, the weather has been crap and I don't want to be in the garage, so a few rides on the turbo trainer to keep the legs and heart working and then a day in the garage.
Frustrating would sum it up. Some days are good days and I feel like I'm making progress, others, I feel like I've bitten off far more than I can chew. I'm past the point now where I'll never get back when I've put into it financially, so by finishing it, I might get some enjoyment back from it and the illusion of time not lost. So on we go.
The rear end is a mess, it needs a lot of work, I have ordered a pair of trailer fenders to use for my inner rear fenders as mine were poorly cut for the over fenders, they were supposed to arrive but didn't. I need to buy new trunk drops, once I do that, I have all the rear parts needed other than some sheet metal to make a few patches here and there. Once the strength is back in the shell, I get get it up on the rotisserie and strip the underside. Before that, I need to lose weight from the front, engine out and all the other bits.
Pulled apart the steering, I need to buy new ball joints and tie rod ends. What's the difference between RHD and LHD or are they all the same? The drag link is different I know that and they can't be built so may have to look to Australia for one. I already have poly bushes in the idler arm but I have replacements for there too and will try re oil the steering box and adjust it to sort out the slop.
This pile of junk will need refurbishing and putting back on
Untitled
More parts in the junk pile that won't be refurbished and re used
Untitled
Cut the spare wheel well out, it got some water in and started to rust out. Not needed anyway so will put some flat 1.5mm sheet to close it off. you can see the 'tide marks' on the fuel cell
Untitled
This pile of junk is to be kept. Thankfully plastic doesn't rust
Untitled
This upsets me, not sure how to tackle it really.
Untitled
Untitled
Untitled
Untitled
Untitled
Untitled
