The Nickel (was belted goon from the weeds)
indy510
Re: covered trailer from the weeds
Post by indy510 » 04 Jul 2016 22:12
RMS wrote:ImageImage
that last pic had me super confused ... :lol: ... nice work!!!
Post by RMS » 04 Jul 2016 22:13
thanks guys
the trim follows the A pillar to the floor. the tricky bit is at the roof fold, it was not calculated (just eyeballed) the gutter dose not line up and will require a triangle or curved filler section as it is very sharp
Re: The Nickel (was belted goon from the weeds)
Post by RMS » 11 Jul 2016 17:49
cleaned up and installed a roof rack on the nickel ImageImage
toung weight is up after I removed the gas tank and 10L of very stale gas (circa 1984) .....I can still smell it.
Im thinking of installing a water tank or at least a block of wood to help support the spare?
McShagger510
Post by McShagger510 » 19 Jul 2016 20:16
The trailer looked even better in person! Great job Robyn! :mrgreen:
Careful with the weight distribution, remember you need to have a bit more weight on the tongue and DO NOT have it 50/50 either....
https://www.youtube.com/watch?v=GymlhreKW0Q
https://www.youtube.com/watch?v=f3VEO8V-XhU
Spied this CL ad today, heh heh...
http://vancouver.craigslist.ca/rds/cto/5593520763.html
'91 Nissan truck
Post by RMS » 23 Aug 2017 08:51
silly wagon wiring.... got 6 wires on the nickel and 6 wires on the sedan.... could I find the brake light wire ? No because the wagon is different........ brakes are fed through the turn signal switch. :x
would I need to feed the brake from the sedan through two diodes to the left and right turn feed ? but if im braking and turning would the lights not stay solid ?
how would I wire this wagon rear harness(L,R,run,reverse) to be operated by a sedan feed (L,R,run,reverse,brake,ground)
Post by two_68_510s » 23 Aug 2017 15:16
This is the best Datsun trailer on the planet, just sayin'.
Post by RMS » 23 Aug 2017 17:50
but how would I wire in brake lights ? :lol: thanks Joel, Im hoping to build another (its a a wait and see situation)..... but kind of useless with out a brake circuit :lol: I could run two wires, one to each tail light and convert the single filament (on the top bulb) with a dual filament disc and bulb.
gooned
Post by gooned » 23 Aug 2017 18:22
They sell a mystery box to combine brake and turn for this, I have one on my Baja to use the heep tail lights.
Post by Byron510 » 23 Aug 2017 23:40
Yep, I used a generic turn signal box in the Mazda we had as well. It takes the separted turn and brake signal and combines them on the trailer to one light (just use both is you have a two bulb tail light. Cost was around $90.
