72 2 Door 510 Restoration-25 years in the making
Re: 72 2 Door 510 Restoration-25 years in the making
Following... I assumed toward the windshield, but now you have me wondering.
Regards,
Owen
65 Sunbeam Tiger MkI
Owen
I have seen a discussion about this somewhere in the 510 universe, but the old brain does not recall the conclusion or where that was.
Maybe Ratsun?
Maybe Ratsun?
I'll swing over there & take a look! Thanks!
Here is a picture of the engine bay, you can clearly see the rubber strip..not sure if it was factory. This car is now in Vancouver.
The idea of that strip was to NOT let air from the engine bay flow out the back of the hood, but, forcing it down and under the car. Most of us do not run one at all for what that is worth.
- hood seal picture
- CANBY 2010 075 (Large).jpg (373.9 KiB) Viewed 424 times
Wow!! That car looks new!! Thanks for the pic, Keith!
I never had one before so I figured it wasn't too critical but I bought the strip when I bought my other rubber bits so I might as well toss it on there. That one looks like it's facing forward so that's one tick in the "forward" column & Owen's guess is one tick in the "windshield" column. I'll keep digging til I find out for certain since it has to be glued in place.
In other news, I have new armrests coming! Yay! Once I get those, maybe people will quit ripping my window crank off!
I have mine mounted with the curve toward the windshield.
Alright! I think I'll go that direction.
Thanks guys!
Thanks guys!
The biggest thing to actually help cooling, is make sure the radiator is sealed up all around the edges.
Air will bypass anywhere it can and you want it to be GOING THROUGH the rad.
Any extraneous holes at the front could be discretely covered also. It all does help!
Damn, that engine and bay is truly spectacular
Stu
1972 4-door 510
2004 Volvo V70R 6spd manual
Factory Five Racing Cobra
1972 4-door 510
Check out what I got! Arm rests! Yay! Now maybe my passengers will quit ripping my window crank off!
And on the 28th (Oct), I was on my way to a Halloween event and the Datsun crapped out! It just totally lost power and didn't want to go. I coasted to the side of the road & called my husband for a tow. I got out of the car because it's a 2 lane highway & I didn't want to get plowed into while sitting in the car as I waited. Several cars slowed down, presumably to ask if I needed help but when I turned to look at them, they sped away! Moral, of the story, grown-ups are literally still scared of monsters!
The points went bad so that's what caused the trouble. I got towed home & all is well.
I DO need a stock fan since mine is in sad shape! What can I expect to pay for one? Are they unobtanium, like everything else?
Sorry to hear about the points/distributor troubles...maybe you could consider something like this?
https://www.the510realm.com/viewtopic.php?t=35101
Thanks for the suggestion! I didn't know there was still an EI made for the L! I'll have to do a little more research.
I've got a fan for you. I'll have to dig it out. Think I paid $45 for it?
