error 406 when posting
Problems, Comments, Questions regarding the website
akara
Post by akara » 28 Mar 2015 12:16
when i try to post to this thread http://www.the510realm.com/viewtopic.php?f=32&t=27859
i am now getting error 406
anybody know what this is about?
Not Acceptable
An appropriate representation of the requested resource /posting.php could not be found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Re: error 406 when posting
Post by James » 28 Mar 2015 13:39
I was able to post on that thread successfully.
Post by RMS » 28 Mar 2015 16:40
im getting the error too
Edit: sure...... so I can post here?
Edit: can I post the body of the text meant for my build thread here?
I don't know exactly what kind of nozzle I have. it came with the Snow Performance kit.
I was running a white/purple 225ml/min @ 150psi jet, on a single dgav (keep in mind that I don't know what Im doing). it was a good kick in the pants @ 3400rpm with 8 in vacuum and 20 percent pump injection pressure. as the rpm increased with lowering vacuum the pump delivered more pressure via a controller. a link to the manual for the kit and the vc-a10 controllerhttp://www.jegs.com/InstallationInstruc ... 0020MC.pdf
assuming i was somewhere in the park with the 225ml/min jet(manual says: 175ml nozzle is recommended for 250 - 300 RWDHP) If I was to split it up and feed each of the 4 runners (before or after the butterfly?) I would need 4X 55ml/min jet(probably smaller like 4x30ml or 2x60ml). the smallest jet offered by snow (according to my manual) is 60ml/min.
yup just had to omit the percent symbol
Post by RMS » 28 Mar 2015 17:06
cant even make a post with only a percent symbol
! @ # $ ^ & * ( ) _ + : " ? > <
yup everything but percent
akara
Post by akara » 28 Mar 2015 18:43
yep that was it, good troubleshooting RMS!
5teN
Site Admin
Post by 5teN » 29 Mar 2015 21:36
Nice find guys! I'll see if I can resolve that!
Cheers
Spencer
Post by Byron510 » 29 Mar 2015 21:51
I got the same error tonight responding to the Nurburgring thread..
For some reason my machine has been picky this past week only on our site. I dumped all the cookies and cleared the memory last week as part of an IT clean up - not sure if this had an effect. You’d think it would help...
Anyways, hopefully it all gets better.
Post by okayfine » 12 May 2015 19:56
The percent symbol is still causing this error. Should have checked here first, but I logged out, logged in, tried another browser, etc. FWIW.
Post by Byron510 » 12 May 2015 21:48
This percent symbol trapped me the other day as well - closed IE, ended up rebooting the machine - still no avail. Then I remembered doing this a couple years ago.... not before almost a fit not being able to figure out the issue.
5teN
Site Admin
Post by 5teN » 28 May 2015 08:01
Spencer
Post by okayfine » 28 May 2015 08:14
:shock:
Post by Byron510 » 28 May 2015 10:26
Ohhhyeah - fixed :D
