36mm Individual Throttle bodies
Re: RE: More Pics
Post by 510rob »
banzai510(hainz) wrote:http://www.modern-motorsports.com/catal ... 08a323de37
Looks pretty long. What about the master clyinders?
Good luck selling them
Let us know how you do.
If you'd like to buy one of those manifolds, say "I"... ...people are watching and listening...
perfectchoicemotorsports
Post by perfectchoicemotorsports »
Hahahaha! Were pretty good with EFI Engine control, but not that good. I've just never seen an engine actuall idle well at that RPM! Although the Model "A" will idle at 250 rpm, my partners actually built a EFI kit for Model "A" and "T".
Guys this is being triggered off the Coil Negative! Which is pretty un-real in the EFI Industry.
Kevin
hang_510
Re: 36mm Individual Throttle bodies
Post by hang_510 »
:shock: bump???
dunno how i missed this :evil:
i think this setup is in my garage now...
now i need to adapt a TPS to it.
seems to be the only missing part.
The TPS on it is a 0 to 5V TPS, the bodies are from a Honda 600F3 If I remenber correctly!
Kevin
Post by okayfine »
perfectchoicemotorsports wrote:The TPS on it is a 0 to 5V TPS, the bodies are from a Honda 600F3 If I remenber correctly!
Kevin
0-5V TPS are pretty common. Most of the Nissan stuff is that way. Brian, you could probably find a TPS for the throttle bodies and use it - I ended up going back to the Suzuki TPS for simplicity when I was playing with ITBs and it worked fine with the KA ECU.
hang_510
Post by hang_510 »
ill look at the honda stuff first...
hopefully adapting it will be a bolt up ordeal :|
thanks for the input!
Post by 510rob »
Brian, could you, would you, post pictures of your setup - we want to see it!!! (exchange of visual ideas)
hang_510
Post by hang_510 »
510rob wrote:Brian, could you, would you, post pictures of your setup - we want to see it!!! (exchange of visual ideas)
me ? pix ??? :lol:
of course... but getting pix online sux for me :twisted: (no home comp)
