Wilwood brakes
Sleepys-14
Wilwood brakes
Post by Sleepys-14 » 18 Oct 2016 19:53
I have a used set of Wilwood calipers and caliper brackets. They will also come with 2 sets of Wilwood compound A pads(half worn). They also have Titanium shims to reduce heat transfer. I can throw in the rotors if need be, but they are $15 on rockauto.
The brake setup works with 280zx struts and 300zx hubs only. I have used this setup with great results for a few years now.
Asking $150 plus shipping of $15 anywhere in the USA.SOLD!!!
Capture 2.PNG (559.53 KiB) Viewed 2429 times
Mattndew76
Re: Wilwood brakes
Post by Mattndew76 » 19 Oct 2016 12:28
Oh VERY nice!
clean71
Re: Wilwood brakes
Post by clean71 » 30 Oct 2016 08:56
pm'd
1971 PL510 4DOOR AUTO
1969 PL510 WAGON 4SPD
1969 PL510 2DR 4SPD
Z-rider
Re: Wilwood brakes
Post by Z-rider » 09 Nov 2016 10:46
If these are still available I will take them.
Sleepys-14
Re: Wilwood brakes
Post by Sleepys-14 » 10 Nov 2016 04:49
They are still available, and my paypal is gordy4549@yahoo.com
Z-rider
Re: Wilwood brakes
Post by Z-rider » 10 Nov 2016 20:40
Money sent. Thanks
Sleepys-14
Re: Wilwood brakes
Post by Sleepys-14 » 11 Nov 2016 05:44
Sold
edakotaford
Re: Wilwood brakes
Post by edakotaford » 02 Mar 2017 10:53
where can i buy a setup like this new? do you know the part numbers/application for the calipers, and are the brackets readily available?
510F22C
Re: Wilwood brakes
Post by 510F22C » 03 Mar 2017 11:47
Arizona Z Car sells nice Wilwood setups. I love mine!
Re: Wilwood brakes
Post by funwithmonkeys » 03 Mar 2017 14:42
There are a bunch of people who sell them. Dp racing, Troy Ermish, techno toys tuning. Almost all of them use the dyna light caliper. If you are going to go with a setup like this you should look at the dyna pro caliper. It is much stiffer and doesn't cost that much more.
Re: Wilwood brakes
Post by bertvorgon » 03 Mar 2017 15:16
Or BRAKEMAN, these are forged and very stiff. I had the JFZ/Wilwoods ( early generations) and found them really flexy, drove me crazy. These are like a brick. They bleed very well also. They do need a custom bracket made for the mounting. BRAKEMAN may have something that bolts onto the 280zx.
If you are NOT racing and this is for the street,DO NOT out trick yourself and get "race" pads. You will never get them up to temp and will have virtually no brakes when cold. Try to get as soft a pad as possible.
What strut/mount do you have?
OUTthere
Re: Wilwood brakes
Post by OUTthere » 03 Mar 2017 20:14
If you decide to buy the TBM brakes ( the brake man brakes), don't tell them you are working on a Datsun because they will never call you back.
Re: Wilwood brakes
Post by 510rob » 03 Mar 2017 22:03
The TBM calipers have a really slick design for their fluid passages and where they put the bleed screw.
Re: Wilwood brakes
Post by bertvorgon » 04 Mar 2017 07:41
I had nothing but good service from them, long discussion on pad type and what I wanted..FOR A DATSUN. Sorry you had a bad experience.
He said they have sold a lot of product for Nissan cars.
These calipers were the evolution of what was the original Mini GN caliper that JFZ developed back in the 80's. They and then the Wilwood equivalent flexed big time. As materials evolved, and better bridging, for all the manufacturers, you now benefit the stiffness of all the calipers.
edakotaford
Re: Wilwood brakes
Post by edakotaford » 06 Mar 2017 07:39
great discussion, thank you all for the input! I have been doing datsuns for about a decade now, and have exclusively used ZX front struts with factory brakes. This time round on my build i would like to have modern braking power, whilst hopefully maintaining use of vintage aftermarket JDM 14" wheels. 13's if possible, but the likelihood of installing modern brakes and still fitting 13's my guess is unlikely.
