window door glass channel felt
68 Wagon
Post by 68 Wagon » 08 Nov 2016 19:46
Need some and cannot find any..............on Google or Ebay..........has it dried up? What gives? Any help would be great here.
Re: window door glass channel felt
Post by RMS » 08 Nov 2016 20:51
510longroof
Post by 510longroof » 19 Nov 2016 13:15
I did my window channels back in 2011. I brought a sample of it to a local hotrod parts supplier and he matched it up to what he had in stock. Turns out it is the most popular size out there. Part number was 3A1 and the price was $42 per 8 foot length. It has a stainless steel spine so it is fairly rigid but is fexible enough for the curve of window track. I had to mitre the 90 bend at the back corner and also the sharp bend at the front of the door. A dab of black silicone seals the seam at each mitre joint and weather strip adhesive holds it firmly in place. For a wagon it took about 6ft to do the front door and a little less for the rear door. Fits really well and looks awesome.
Check auto body suppliers or even parts suppliers like Napa. If they stock it or can get it then you save yourself some shipping.
This is what you are looking for.
https://www.hitechglazing.com/product/40051
Hope this helps.
71 510 wagon
67.5 1600 roadster project
74 CB360T project
I was in film, then television and now radio.
zKars
Post by zKars » 20 Nov 2016 07:01
The term to search for is "window" or "glass" "run channel".
This is one example supplier on ebay, "Rubber the right way"
http://stores.ebay.com/Rubber-The-Right ... 4340.l2563
zKars
Post by zKars » 20 Nov 2016 18:17
I dug my glass run channel run felts that I haven't installed yet out. They are the 5/8" wide by 1/2" high stuff. Fit perfect in the run channels of my 69 4door.
