Cranking issue
Re: Cranking issue
Post by bertvorgon » 08 Dec 2016 07:28
For what it is worth, they ( the first re-builders) did put a new solenoid on.
It is freak'in freezing in the back of the plant right now, but as soon as it warms up a bit, I am going to put EVERYTHING back together, cleaned, and start again ( pun intended).
If no go, I will put in Robyn's starter and see what happens..
I still am going to get a load test done on my battery...just because and it cost nothing.
I also have put into place my ARMSTRONG starter system, retro fitting the front pulley with one from a 1948 Austin A-40 ( of which I once owned) along with the crank handle. I use to start my Austin with that on occasion. I have asked Santa Claus for a gym membership, so I can get my right arm stronger, as cranking the 10:0 compression, could be an issue, I think the compression on the Austin was down to 7:1 before it finally died on me.......
Re: Cranking issue
Post by RMS » 08 Dec 2016 08:20
no thread jack
Chickenman wrote:You still battling with the wagon Robyn?
no that was bad gas :x
I cant seem to get the duals to stop choking and spiting on the 68. no thread jack
Keith let me know when you start tripping over the excess starters and I will come take them away.
Re: Cranking issue
Post by bertvorgon » 08 Dec 2016 08:32
I will Robyn, I am staying on this project till finished, I do not want to be fighting this in the spring.
I have pulled one starter out, which I will buy as a spare anyhow, let me know what you want for it.
Chickenman
Re: Cranking issue
Post by Chickenman » 08 Dec 2016 09:10
bertvorgon wrote:For what it is worth, they ( the first re-builders) did put a new solenoid on. (Snip)
I'll bet you a Starbucks it was a POS off shore brand... You can't get anything of quality these days.
Re: Cranking issue
Post by RMS » 08 Dec 2016 09:23
the convenience of the bertvorgon datsun parts shipping program is much appreciated, the starter is free
66DUCE
Re: Cranking issue
Post by 66DUCE » 08 Dec 2016 13:17
Good call on load testing the battery before you put it back in the vehicle, cleaning all connections on both ground and positive side will also eliminate any voltage drop. I realize that when you bypassed all the wiring in the car and the starter did the same thing pointed to the starter. Remember a re builder will only bench test a starter (no load) and any issues (like high resistance) may not show up as in cranking a high compression engine. As mentioned by another poster there could be corrosion/ burned terminal on the solenoid that will not show up on a bench test but will show up on cranking the engine. Again careful voltage drop of each component on the pos/neg side should show you where your problem is.
Re: Cranking issue
Post by bertvorgon » 08 Dec 2016 16:09
I agree with you, as I drove away..I realized that he did not do any sort of load test, so of course it spun just fine.....
Re: Cranking issue
Post by bertvorgon » 13 Dec 2016 16:33
Well, here is the final outcome, after chasing my tail in some ways.
Made an assumption that my starter was re-built two years ago, must be good! Period..simple as that.
I put in the starter Robyn has kindly donated to the Great Rolling Dyno...and it cranked like it has not in a long time...PERIOD.
I put all my spark wires on today and it lit off in an instant and that was at 39F. ambient temp.. I would suggest that the starter had issues not long after it was rebuilt, as I put my warrantied NEW battery in at the same time. I keep a log book and it was not long after that that my cold(ambient) first start of a day would give me an occasional issue.
Obviously a NON-LOAD starter test proves nothing..YUP the motor spins...big deal..but it produces no TORQUE.
I phoned the guy that tested it and he thinks it may be a bad spot on the armature, we will see. I am going to take it in and get him to take it a part and hopefully fix it, and that will let us know for future reference.
Re: Cranking issue
Post by RMS » 13 Dec 2016 17:29
good to hear the the issue has been sorted. helping you out with a starter validates my give a core take a core efforts.
Re: Cranking issue
Post by bertvorgon » 13 Dec 2016 19:07
Yah, thanks Robyn, that puppy is just going to stay in the car now. I put it up and jack stands today, this year is DONE!
I have a headlight project for the winter, plus the usual nut and bolt check.
Stay tuned for the year in review and 2017.
Re: Cranking issue
Post by 510rob » 13 Dec 2016 19:42
bertvorgon wrote:I have a headlight project for the winter, plus the usual nut and bolt check.
Is it already time to give those babies a top-up of halogen fluid?
Re: Cranking issue
Post by James » 14 Dec 2016 05:57
bertvorgon wrote: he thinks it may be a bad spot on the armature.
This would make sense, as the armature may land in that bad spot one time out of 5. Glad you figured it out!
Re: Cranking issue
Post by bertvorgon » 14 Dec 2016 07:22
Thanks, I just hate electrical problems.
Re the headlight project. Ever since I saw Byron's crazy bright lights at Knox, I have wanted to do the proper upgrade for better night lighting. As many of our drives both start and finish in the dark, it's time for it.
Back in May, I started looking at options, trying to make sure I was not missing something modern. I was not convinced that LED's were that good yet and ultimately am still on that thought. They are bright, but, the lense's still do not project as good as I want.
I stumbled onto a fellow down in the States, who seems to have it together as to what would WORK IN MY 510 ( and lighting in general in my opinion). In the new year I am going to bite the bullet and order what he has recommended and will report on how well that goes.
Our CDN dollar has gotten a bit better, so the pain will not be as bad.
Chickenman
Re: Cranking issue
Post by Chickenman » 14 Dec 2016 08:47
Have you looked at Cibies Keith? Still the Gold standard for lighting. Was it Daniel Stern lighting that you contacted? If not you should have a look at his site.
http://www.danielsternlighting.com/
Lens design and reflector design ar just as important, or more important, than bulbs. Accuracy in cut off is a priority and Cibies excel at that.
Re: Cranking issue
Post by bertvorgon » 14 Dec 2016 09:07
Hey Richard,
Yes, it was Daniel, I had a LONG discussion with him. Very interesting for sure.
