original tires
dat5102dr
original tires
Postby dat5102dr » 27 Feb 2017 02:34
does anyone know which company sells original tires? similar original? with good reputation?
Re: original tires
Postby Byron510 » 27 Feb 2017 03:49
I ordered a set of Micheline 155 R-13 radials from Coker Tire for one of my cars a few years ago. Cost was reasonable, and they were 1" white walls.
It's about as close as I could find to a 'stock' tire size in a Radial. The originals were of course Bridgestone bias-ply tires and these are simply not available.
Coker also lists a BF Goodrich 560-13 in a 1" and 2 1/4" white wall and a 2 1/2" Firestone white wall if you wanted to go the bias-ply route for your car.
Hope that helps.
Re: original tires
Postby okayfine » 27 Feb 2017 05:56
Coker is your best bet. Summit Racing is a reseller.
Re: original tires
Postby two_68_510s » 27 Feb 2017 11:11
Yep, they had original looking wide whites for my 50 Olds.
Return to “Suspension”
