New datsun parts problem
dat5102dr
Postby dat5102dr » 09 May 2017 22:52
510RU05 part #
they fit perfectly on my trunk but
not on the doors
I have 71 2dr
anybody have a similar problem?
toylet
Re: New datsun parts problem
Postby toylet » 10 May 2017 10:49
Next time buy good stuff from Datsport. Problem solved
dat5102dr
Postby dat5102dr » 10 May 2017 11:06
maybe I missed it
but I don't see it on their list
part#
description
price
BSR1601
Front windscreen moulded seal takes standard stainless moulding
115
BSR1602
Rear windscreen moulded seal takes standard stainless moulding
115
BSR1683 Front windscreen moulded seal takes wide original SSS or deluxe stainless moulding
187
BSR1684 Rear windscreen moulded seal takes wide original SSS or deluxe stainless moulding
168
BSR1691 Front windscreen moulded seal NO stainless moulding smooth type NEW
136
BSR1692 Rear windscreen moulded seal NO stainless moulding smooth type NEW
132
BSR1673
Front door weather strip, this is the main door seal, fits RH LH doors, each door
48
BSR1605
Boot or trunk weather strip , this is the main boot/trunk seal
52
BSR1606
Rear bumper splash seal, fits the rear body panel join between bumper & body
22
BSR1607
Bonnet or hood to firewall seal, this one stops water getting in the fuse box
22
BSR1618
Front door glass baily channel, the window glass runs in this, fits RH LH, each door
30
BSR1664
Front door outer window belt seal, fits on the stainless moulding fits RH LH,each door
32
BSR1665
Front door inner window belt seal, fits on the inner side of the door RH LH, each door
26
BSR1666 Rear butterfly window pinch weld, RH LH each. 2 required per car
24
BSR1668 Rear butterfly window frame to body weather strip. each. 2 required per car
52
BSR1670 Rear butterfly window frame to glass moulded seal RH NEW
77
BSR1669 Rear butterfly window frame to glass moulded seal LH NEW
77
BSR1620
Front door pinch weld ,long, to go completely around the door frame if kick panels are not used, trim to size as required RH LH, each door 2 required per car
25
BBS1631
Bonnet or hood bump stops, supports the bonnet or hood, full kit
14
BBS1632
Fuel filler flap bump stops pair
6
BBS1633
Boot or trunk lid bump stop kit pair
14
SLK51F-14 Rear tail lamp/combination lamp to body seals & lamp to lens seals per pair
52
DLR1600 Door latch anti rattle rubber,for door latch mechanism , genuine unlisted part
NLA
EFS1601
Fuel filler tube replacement part
NLA
TCB1200
Gear lever boot genuine part for conversions
39
BFR1625 Replacement rubber for bumper over rider SSS each
toylet
Postby toylet » 10 May 2017 20:45
BSR1673
front door weatherstripping
MikeY
Postby MikeY » 10 May 2017 21:50
Took me a while to figure out what he was talking about
It really helps to inquire with full sentences. And usually enough to make a paragraph or 2.
Op has the door bumpers from new Datsun parts. Not the door seals. New Datsun parts sell 4 for $11. The are the small ones for a 4 door and will work for the trunk. If I'm not mistaken the bumpers for a 2 door are larger. Looks like they are not available from new Datsun parts. I wonder who else sell this size. I have picked up some from Motorsports auto that were for a 280zx hatch. They looked similar to the large ones. But I'm not certain they are the same.
Colbino
Postby Colbino » 10 May 2017 23:20
I think these are what you're after...
https://www.zeddsaver.com/collections/d ... or-bumpers
Return to “General Discussion”
