Speed Sensor (VSS) for 4 Speed Transmission
ohenry
Post by ohenry » 09 Sep 2017 17:36
I'm hoping someone might know if there is a speed sensor (VSS) I can use for on a 510 4-speed transmission. I recently bought a Speedhut electronic speedometer and was under the impression a 240sx speed sensor would work but it doesn't seem like it will.
Any idea on what I can do to get the speedometer working?
Thanks in advance
broke
Re: Speed Sensor (VSS) for 4 Speed Transmission
Post by broke » 09 Sep 2017 20:31
I'd try one of these Marlin Crawler speedo adapters
https://www.marlincrawler.com/transfer- ... sensor-mci
Toyota and Nissan both use M22x1.5 and my Celica Supra speedo cable end looks exactly like my Datsun one so assuming the pulse outputs are compatible you should be fine.
-McWicked
Post by Three B's Racing » 11 Sep 2017 04:33
Send it back for a GPS Speedo.
zKars
Post by zKars » 11 Sep 2017 10:05
That Martin crawler thing is a fantastic solution for more than just speedo drive. EMS speed input, cruise control etc etc etc.. I'm gettin' one! $49?? Cheeeepppp
The Speedhut GPS solution is the best way to solve ohenny's problem assuming the old one is returnable of course.
ohenry
Post by ohenry » 11 Sep 2017 14:36
Thanks for the replies!
Sadly I'm past the return period. I'll give the Marlin Crawler a shot and hopefully things work out.
chunstone
Post by chunstone » 13 Sep 2017 15:54
what about some gps unit that cost $89 on ebay with built in sensor, just slam into dash and your checking your speed against the Law Enforcement thugs!
170 hp-180 tq
