Vg33 wiring
lovememydatsun
Vg33 wiring
Post by lovememydatsun » 01 Nov 2017 12:30
Hey guys, so currently I’m am in the process of swapping a vg33 on my 510, and I was wondering would i be able to use an automatic Nissan Quest ecu and harness to start my car up even if I have a 5 speed installed? Any info would help. Thanks.
Re: Vg33 wiring
Post by okayfine » 07 Nov 2017 17:25
Apropo of nothing specific to your question, but I ran a '95 KA24DE on an auto ECU and harness even though I had a manual trans. Wiring also wanted the crank position sensor mounted in the bellhousing, which I did not have hooked up either. No problems, ran great.
Re: Vg33 wiring
Post by icehouse » 07 Nov 2017 19:56
I can't say for sure but I don't think it will work. Of coarse I can't remember for sure but I was at a buddies legit shop, he was working on a customers van (can't remember which one, but not a nissan) with a VG and it won't run with the crank sensor unplugged. So unless you plan on added sensor it might need I would find the Nissan stuff you need.
Heinrich
Re: Vg33 wiring
Post by Heinrich » 07 Nov 2017 22:30
i have used Automatic Nissan J30 Maxima ECU's twice on manual VG33 setups without any auto stuff connected.
worked without any hassle.
Reason i used them is because there was no security systems (NATS) on Maxima ecu and the ECU fit the Pickup Loom we have here.
not sure if Quest and maxima works exactly the same tho.
