Wanted 5.1 crown wheel & pinion set for a R180 diff
1600SSS72
Post by 1600SSS72 » 22 Apr 2018 02:29
I need a 5.1 (or 4.875) crown and pinion for a long nose R180 diff.
Re: Wanted 5.1 crown wheel & pinion set for a R180 diff
Post by funwithmonkeys » 22 Apr 2018 15:31
You should specify which internal diameter of the crown also. For the R180 there are 2. 110mm for the older Datsun stuff and the newer diffs with the K cast in the casing are 115mm. Just an FYI, I found out the hard way.
1600SSS72
Post by 1600SSS72 » 23 Apr 2018 11:27
Thank you, I am using a Subaru WRX R180 4.44 lsd, but as it is mounted in car I cannot verify but I would appreciate if someone knows.
Post by funwithmonkeys » 23 Apr 2018 11:32
That will be a 115mm.
1600SSS72
Post by 1600SSS72 » 23 Apr 2018 11:34
Thank you.
