620 KC project
Re: 620 KC project
Post by datzenmike » 14 Feb 2020 19:49
Hopefully the tension rod bushings are rubber and not poly.
Edm620
Re: 620 KC project
Post by Edm620 » 27 Feb 2020 10:34
Yup, initial joint done early June in Mexico (fantastic surgeon) but got infected, 2 surgeries in attempt to clean out without success so a temp joint put in that didn't last at all so another joint put in. Still working on rehab
"If you don't know where you're going, any road will take you there"
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 27 Feb 2020 10:38
Actually I have gone with the poly bushings - why do you suggest going with rubber? These are not the torsion rods to be clear
datzenmike wrote:
14 Feb 2020 19:49
Ugandan Proverb
Re: 620 KC project
Post by datzenmike » 27 Feb 2020 18:48
Edm620 wrote:
11 Feb 2020 10:32
At long last I have been able to get back out in my garage and get back to work on the project, yesterday I spent a few hours cleaning my space up and then completed the installation of the new tension rod bushings which had arrived back in June. My triple hip replacement had really beat the stuffing out of me so I can finally smile and get my hands dirty again :D .
Today I plan to get the axle shafts reassembled in preparation to stuff into the housing along with the freshened-up pumpkin. It's been so long since I took it all apart I may actually have to read instructions! Next to-do is figure out the rear sway bar mount-up as I expect the fuel tank will be somewhat in the way. I'll post pics once I have that figured out.
Tension rods form a triangle with the LCR so when you hit bumps or the brakes the wheel does not get pulled to the rear. However the tension rod must swing freely up and down with the wheel at the outer end of the LCA. Rubber will compress, poly not so much, so the rod is forced to bend back and forth. This can lead to catastrophic failure from metal fatigue.
You might drill several holes to allow some compliance but best of all is to stay away from any poly suspension parts all together. Rubber is far superior for wear, and vibration isolation and they don't squeak.
Edm620
Re: 620 KC project
Post by Edm620 » 27 Feb 2020 20:24
OK thanks for the tip Datzenmike on why the rubber. I'm going to stick with the poly for now but I will definitely keep that advice in mind. :)
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 27 Feb 2020 20:28
Edm620 wrote:
11 Feb 2020 10:32
Turns out I wasn't really joking! Had a big brain fart today during reassembly and totally missed a step, started installing the axle bearing BEFORE I put the backing plate on. Thankfully I got that brain cell functioning again before I got it driven all the way on. :shock:
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 03 Mar 2020 15:29
Today I got the aftermarket rear sway bar mocked up in a "reverse" mount due to the fuel tank being in the way to mount it the "normal" way. Now to weld up the mounting brackets to the axle housing plus fabricate mounts for the frame ends of the bar.
IMG_5499 small.jpg (613.04 KiB) Viewed 348 times
IMG_5495 small.jpg (544.43 KiB) Viewed 348 times
IMG_5494 small.jpg (669.42 KiB) Viewed 348 times
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 14 Mar 2020 18:27
Rear sway bar now complete, made a much better mount-up and improved the angle of the bar ends.
Next big task is to install the pumpkin and axle shafts
IMG_5542 small.jpg (188.23 KiB) Viewed 251 times
IMG_5541 small.jpg (265.06 KiB) Viewed 251 times
Ugandan Proverb
demo243
Re: 620 KC project
Post by demo243 » 16 Mar 2020 09:21
Cool to see another 620 on here! Keeping an eye on this thread.
I am working on a '78 Single Cab
Image20200311_173505 by devon M, on Flickr
'71 4 Door - Street/AutoX/Track Day Romper - NOW powered by a Carb'ed KA24DE
Edm620
Re: 620 KC project
Post by Edm620 » 18 Mar 2020 16:42
Got a little more work done today, made the new rear brake lines and cleaned up the splitter block. Tomorrow I plan to get the differential installed so I can put the axles in and finish the rear brake reassembly.
IMG_5550 small.jpg (312.9 KiB) Viewed 178 times
IMG_5549 small.jpg (337.32 KiB) Viewed 178 times
IMG_5548 small.jpg (379.33 KiB) Viewed 178 times
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 21 Mar 2020 09:08
demo243 wrote:
16 Mar 2020 09:21
Good looking truck. Body parts seem the hardest to find.
Ugandan Proverb
Edm620
Re: 620 KC project
Post by Edm620 » 21 Mar 2020 09:19
Getting some work done on a daily basis, have completed the install of the differential, axles, and rear brakes minus the park brake cables as the ones I received seem to be for a reg cab shortbox. Should be ready to make my new fuel & brake line bundle soon, will also be making new retainers for the lines.
IMG_5558 small.jpg (420.03 KiB) Viewed 148 times
IMG_5555 small crop.jpg (100.96 KiB) Viewed 148 times
Ugandan Proverb
SteveEdmonton
Re: 620 KC project
Post by SteveEdmonton » 23 Mar 2020 08:36
What a great project! You're doing a super job. I'm here in Edmonton too-- wouldn't mind coming to see what you're up to, when all of these restrictions ease. In the meantime, keep plugging away! That's going to be one terrific truck when you get it done.
Cheers,
Steve
'71 4-door
'74 MGB-GT
'04 Miata
demo243
Re: 620 KC project
Post by demo243 » 24 Mar 2020 12:20
Edm620 wrote:
21 Mar 2020 09:08
Thanks! The floors are rough... but the rest of the body is pretty good.
Keepen an eye on this thread to watch yours come together
Edm620
Re: 620 KC project
Post by Edm620 » 25 Mar 2020 22:42
demo243 wrote:
24 Mar 2020 12:20
Edm620 wrote:
21 Mar 2020 09:08
Floor rot isn't uncommon, I'm going to have to do some lower body rebuilding once I get to that stage. The rockers were pretty much rotted through and I did see some re-pops listed on Ebay long ago but I didn't buy then, guess I should have. Pretty much anything mechanical is easy enough to find though. What are you planning to do with yours?
Ugandan Proverb
