Gold digger
cwd240z
Re: Gold digger
Post by cwd240z »
Great looking seats. I'm looking for a carpet kit as well...
Chris
'71 510 4-Door Sedan
'76 280z
Stu
Re: Gold digger
Post by Stu »
Love the seats. Where did you end up finding them?
Stu
1972 4-door 510
2004 Volvo V70R 6spd manual
Factory Five Racing Cobra
Heinrich
Re: Gold digger
Post by Heinrich »
i long for a set of those seats, we had them here in the alfa giulietta's in the 80's iirc.
iceman510
Re: Gold digger
Post by iceman510 »
Stu wrote: 26 Aug 2021 21:32 Love the seats. Where did you end up finding them?
Yes! And are they new or used (don't think Recaro makes that style anymore)?
eastbaysolo_73
Re: Gold digger
Post by eastbaysolo_73 »
cwd240z wrote: 26 Aug 2021 21:24 Great looking seats. I'm looking for a carpet kit as well...
Thanks. I ended up buying a kit from a guy locally who sell them.
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
I got them from the Recaro FB page. They came from Malaysia. Seats are authentic just reupholstered .Thanks :mrgreen:
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
Heinrich wrote: 26 Aug 2021 22:15 i long for a set of those seats, we had them here in the alfa giulietta's in the 80's iirc.
Get your self a set bud.
My build thread
Nor Cal Meng !
cwd240z
Re: Gold digger
Post by cwd240z »
eastbaysolo_73 wrote: 27 Aug 2021 08:06
Oh ok... be sure and post some pics of the carpet and how it fits, I'd like to see it
Chris
'76 280z
eastbaysolo_73
Re: Gold digger
cwd240z wrote: 27 Aug 2021 19:12
No problem. He's been selling these kits for a long time on Ratsun website and maybe here a while back. His name is Mario Guerrero if your on FB.
Heres a photo of the carpet installed it sent me.
Imageinstalled carpet by v p, on Flickr
Imagecarpet kit by v p, on Flickr
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
Got the Futofab rear bumper and brackets installed. Had a few issues but I got it sorted out. This bumper is nice . Im very satisfied with quality. Cant wait till the front bumpers are back in stock. :mrgreen: :mrgreen:
Imageimage0 by v p, on Flickr
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
Ok so here's an update while I wait for the Seatbelt stuff and Wedge seat brackets. I found a solution to using my Evo E-brake handle with center console. Its from GKtech. Here's a little mock up video demonstrating how it will work. It has an inline Wilwood MC which is pretty sweat. Console sits right over it and its hidden from anyones view. Please excuse the crude look of it. Its just mocked up. I need to add some spacers to level it up.
https://youtu.be/EhZPcFwnLRA
My build thread
Nor Cal Meng !
iceman510
Re: Gold digger
Post by iceman510 »
So no cables will be used? Do you splice that m/c into the single brake line to the rear? Basically a line lock.
eastbaysolo_73
Re: Gold digger
iceman510 wrote: 08 Sep 2021 11:29 So no cables will be used? Do you splice that m/c into the single brake line to the rear? Basically a line lock.
I couldn't use the cable like I planned with the T3 set up that came with my brake kit. The cable when attached to the caliper was making contact with my face bolts on the wheels. Also the mounting bracket for the cable on the caliper stuck out to far. Yes splice it in. You can call it line lock. The hole point to this was to utilize the EVO handbrake with the console. And if you wanna slide you have the capability if thats your thing. It looks clean with the console on. So im happy. :mrgreen:
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
Got the carpet kit ,wedge brackets and sliders for my Recaro seats. The seat belts should be in this week too. Im planning on installing this stuff this Saturday. So photos and videos to follow. I did find a problem trying to adjust my turbo blanket spring. The turbo drain tube was leaking at the flange and weld. Glad I found it before I actually drive this thing. Would have been a fire for sure. Turns out when I welded the bracket I might have slightly warped the flange. As far as the cracks concerned I did have to add slight bend to the tube after welding it. Pretty sure thats what did it. Turbo and lines are already removed. Just have to install the new oil flange gasket and button it up and should be good to go. I also have to make some brackets for the EVO console to have it securely mounted in place. Im gonna use rivnuts for sure just not sure on what to use for the actual brackets. Either way progress. Here's a photo of my fuse box mounted under the drivers side of the dash. I don't believe I have a photo of this yet. :mrgreen:
Imageimage0 5 by v p, on Flickr
My build thread
Nor Cal Meng !
eastbaysolo_73
Re: Gold digger
Got the seat brackets installed and sliders on the seats from Wedge engineering. Here's photo and small video I uploaded on my Youtube channel on how I went about it.
Imageimage0 6 by v p, on Flickr
https://youtu.be/mUmPloCONy4
Also re-installed the fixed turbo drain. So made some good progress. Seats are just mocked up. I have to install carpet before I tighten everything up.
My build thread
Nor Cal Meng !
