Diff to crossmember torque specs
eastbaysolo_73
Post by eastbaysolo_73 » 22 Mar 2019 12:55
Did a search but didn't come up with a exact number. I found a thread that said 52lbs but not sure if thats for the Mustache bar or the 4 bolts that hold the diff in place on the rear X-member. I need both the 4 bolts and mustache bar. Thanks in advance to anyone who chimes in.
ImageRearend by v p, on Flickr
My build thread
Nor Cal Meng !
Re: Diff to crossmember torque specs
Post by Byron510 » 22 Mar 2019 13:50
As all bolts are M12x1.25 pitch, you'd think they would be the same torque spec.- but that's not the case.
Straight out of the FSM - Pages RA-4 & RA19-20;
Rear suspension member mounting lock nuts (Outer X member) 10 kg-m - 72 ft lbs
Differential mounting member (mustache bar to body) 8.5 kg-m - 62 ft lbs
Differential to differential mounting member (diff - Mustache) 6kg-m - 43 ft lbs
Differential to suspension member (diff - X Member) 6kg-m - 43 ft lbs
And in case you wanted to check;
Suspension Arm to Suspension member lock nuts 8-10 kg-m - 58 - 72 ft lbs
2019-03-22 Diff Mount torque specs3.jpg (97.75 KiB) Viewed 1893 times
2019-03-22 Diff Mount torque specs2.jpg (120.75 KiB) Viewed 1893 times
2019-03-22 Diff Mount torque specs1.jpg (85.01 KiB) Viewed 1893 times
eastbaysolo_73
Post by eastbaysolo_73 » 22 Mar 2019 14:55
Wow thanks Byron510 I would have never known. Maybe this thread should become a sticky? Incase others need the same information.
My build thread
Nor Cal Meng !
68Datsun510
Post by 68Datsun510 » 27 Mar 2019 05:25
When the impact goes ratatatatatat lol
_________________________________
Cody Mould
'69 510 4-Door
Cameron Park, CA
Sacramento Datsun Owners
~Visit Sacramento Datsun Owners on Facebook!
Tedman
Post by Tedman » 31 Mar 2019 21:47
FYI Installing the long diff-to-crossmember bolts from the bottom makes it possible to remove the diff from the car without having to drop the crossmember. They look to be installed from the top in your original post.
68Datsun510
Post by 68Datsun510 » 01 Apr 2019 02:52
Good catch Ted, that'll cause some trouble down the road for sure...
Cody Mould
'69 510 4-Door
Cameron Park, CA
Post by Three B's Racing » 01 Apr 2019 05:23
Tedman wrote:
31 Mar 2019 21:47
You don't need to drop the rear crossmember. What you could do is simply remove all neccessary holdings and raise the back of the 510 up off the member, there that should do it. :?
eastbaysolo_73
Post by eastbaysolo_73 » 02 Apr 2019 12:56
Tedman wrote:
31 Mar 2019 21:47
Yeah that was addressed already. Thank you
My build thread
Nor Cal Meng !
eastbaysolo_73
Post by eastbaysolo_73 » 02 Apr 2019 12:57
Its all installed correctly now and torque to factory specs. Thanks fellas for all the info.
My build thread
Nor Cal Meng !
