Wiring harnesses-- "engine room" (main)
SteveEdmonton
Post by SteveEdmonton » 20 May 2019 14:26
Time to clean out my stash and pass these along to whoever can use them. All are "engine room" harnesses (= the main harness, mostly under the hood but also extending through the firewall into the passenger compartment). I'm supplying parts numbers, vehicle details, and dates, where known. Where not listed, this information is unavailable.
Note: the first 4 harnesses are uncut, the 5th is repaired and perfectly serviceable, the last 2 have had one or two branches cut off. Prices reflect this. (Sorry, the pictures are scrambled-- I think they're all present if you keep scrolling down, but I can't figure out how to sequence them properly!)
All prices are in USD and shipping from Edmonton, Alberta, is EXTRA.
# 1 uncut engine-room 24012-N0910 Aug 70 onward sedan auto trans incl 5 relays + fuse-box $150 USD
Harness 1.JPG (123.67 KiB) Viewed 761 times
#2 uncut engine-room 24012-N2705 Jan-Mar 72 sedan auto trans incl 6 relays $135 USD
Harness 2.JPG (127.98 KiB) Viewed 765 times
#3 uncut engine-room incl 5 relays $125 USD
Harness 3.JPG (127.13 KiB) Viewed 765 times
#4 uncut engine-room incl 2 relays $125 USD
Harness 4.JPG (125.44 KiB) Viewed 765 times
#5 repaired engine-room wires fixed, or taped together $100 USD
#6 cut engine-room 24012-N2210 Apr-Jun 72 wagon manual trans incl 1 relay, but several cuts $80 USD
#7 cut engine-room $60 USD
Harness 7.JPG (122.54 KiB) Viewed 767 times
Harness 6a.JPG (122.44 KiB) Viewed 767 times
Harness 5.JPG (120.5 KiB) Viewed 767 times
Harness 4.JPG (125.44 KiB) Viewed 767 times
Harness 3.JPG (127.13 KiB) Viewed 767 times
Harness 2.JPG (127.98 KiB) Viewed 767 times
'71 4-door
'74 MGB-GT
'04 Miata
BB510
Re: Wiring harnesses-- "engine room" (main)
Post by BB510 » 29 May 2019 16:00
Do any of your wiring harnesses include the Fuseable link?
SteveEdmonton
Post by SteveEdmonton » 29 May 2019 19:40
That's a great question. Off hand, I'm not sure! I'm guessing the answer is YES, because they provide all of the wiring leading to the starter. But let me look into it and I'll let you know for sure.
Cheers, Steve
'71 4-door
'74 MGB-GT
'04 Miata
SteveEdmonton
Post by SteveEdmonton » 31 May 2019 07:06
Yes, I checked the best of the harnesses and the fusible link is definitely there.
Open to offers! :)
'71 4-door
'74 MGB-GT
'04 Miata
BB510
Post by BB510 » 31 May 2019 08:03
Can you post a photo or send me a photo of it so I can verify it looks correct? Thanks!
paplos1
Post by paplos1 » 21 Oct 2019 06:46
I would like to buy the engine compartment harness
and the
interior with switches included
what can you do for a package deal??
shipping should be easy per USPS flat rate
from 7.90 - 14.35 depending on which box is used
you can call me @ 408-310-2345
SteveEdmonton
Post by SteveEdmonton » 21 Oct 2019 06:57
Hey, thanks for your interest.
Is this the interior harness you're interested in-- the first one shown here, listed as #8? http://the510realm.com/viewtopic.php?f=10&t=31630 If that's what you're after, yes I still have it. And for sure let's make a combined deal.
On this page, which one of these "main" harnesses do you want? Let me know.
As for shipping, I'll need to use Canada Post, so the prices will be higher than what you mention. I'll get you a quote, though, so you know what you're looking at.
In order to do that, I'll need your name and full mailing address. Maybe we can shift to texting, for that.
Cheers;
Steve
'71 4-door
'74 MGB-GT
'04 Miata
