Subaru R180 diff in Nissan case
iceman510
Post by iceman510 » 12 Jun 2019 06:51
Hey all, I hope someone out there has done this and can chime in. I acquired an R180 Subaru CLSD unit bare, and I am looking to put it in my Nissan 720 truck housing with the 4.38 ring and pinion. It is the K housing, so I am thinking this should fit. This installation shouldn't really be any different than doing an aftermarket diff installation basically, right?
I have compared and measured the two, and within my capability and tool accuracy of measuring I see about a 0.5 mm difference in the ring gear mounting surface to bearing outer case dimensions (measured both directions). I am thinking this should be within the scope of adjusting with the side case shims.
I plan to use the matching ring and pinion from the truck. Any advice on pitfalls for recommendations appreciated. Photos below. Thanks in advance.
Subie clutch diff
subi diff small.jpg (176.5 KiB) Viewed 2622 times
iceman510
Re: Subaru R180 diff in Nissan case
Post by iceman510 » 12 Jun 2019 06:56
Hmmm, dropped two pictures for some reason.
The attachment datsun _subi diff small.jpg is no longer available
datsun _subi diff small.jpg (208.82 KiB) Viewed 2620 times
Post by funwithmonkeys » 12 Jun 2019 11:53
I found out the hard way that there are 2 different ring gear sizes. The older Nissan ones are 110mm ID and the newer ones are 115mm ID.
iceman510
Post by iceman510 » 12 Jun 2019 12:32
I didn't check that yet, but I need to to make sure. Truck unit is a considered the newer type I believe, so it should match.
Post by JordanTr » 13 Jun 2019 08:37
funwithmonkeys wrote:
12 Jun 2019 11:53
Do the bolt PCDs line up still? Could always do some machining to make it work if that’s the only issue.
Post by funwithmonkeys » 13 Jun 2019 08:40
From what I understand the bolt pattern is the same. I just got the Cusco LSD to fit the 110mm ring gear.
iceman510
Post by iceman510 » 16 Jun 2019 19:53
Did some exploration on this today. The ring gear inner diameter is 115 mm, so no problem fitting the CLSD unit. After removing it I could also establish the distance from mounting flange to bearing is identical on the two units.
One issue to adapt is the bolt size. The Subaru LSD flange has 11mm bolt holes, and the Datsun ring gear uses 10mm bolts. They are also a bit short since the flange is thicker. I will likely mod the bolt holes to use the Subaru LSD bolts mentioned in some other posts here (8002 11140).
One other issue, the Datsun diff has the metal locking straps that fold up across two bolts. These will likely not fit because the contour and shape of the surface is different. Is loctite sufficient to hold these, or should I modify the lock tabs somehow to work? Sorry, I will have to get a picture of those.
Post by JordanTr » 16 Jun 2019 20:05
If you clean/degrease the threads, a Loctite product would suffice. Red 272 @ ~2900psi shear strength or 680 retaining compound @ ~3700psi shear strength would be good options to consider.
iceman510
Post by iceman510 » 17 Jun 2019 10:10
Researching further today and talking to some people in the business, it is suggested that the ring gear will be hard enough material that it may be difficult or near impossible to drill and tap those holes larger. I know Kurt mentioned having that done in the original FAQ written about this many years ago (or maybe it was someone else, there are so many versions of that doc around).
The Nismo bolts are NLA. :( Subaru bolts are easy to get, but maybe not usable. Interestingly enough, those show on the ordering site as only 20 mm long. I will have to check my notes again tonight, but I think the original 10mm were almost the same. I suspect I may be going the sleeving holes route.
Post by Byron510 » 23 Jun 2019 20:07
Keep us posted- certainly interested in what you find out in the end.
Tanks for taking the time to post.
iceman510
Post by iceman510 » 24 Jun 2019 05:36
I found and ordered spacers (set of 10 from ebay) that are designed to sleeve bolts on some Dana ring gear applications. They are here:
https://www.yukongear.com/productdetail ... rodID=8508
These initially appear a bit pricey at over $5 a piece, but the set of 10 were just over $30. Need 8, so not a terrible deal. Guy at the local diff shop told me they use compression fitting ferrules and pound them in to fit. Thought this might be better.
Anyway, the OD of said 7/16" was just about 11.2mm. They tapped into the holes in the Subaru diff unit with a nice snug fit. The ID of said 3/8" was too small for the Nissan bolt of 9.95 mm diameter, so I filed the ID with a round file until the bolt fit through snugly. Looks like this will work. I only completed one so far.
Bolt engagement into the ring gear will be a very minimal bit shorter than original. I don't remember exactly now (wrote it down in the garage), but it is less then half a thread, I think about 0.5mm with the thread pitch of 1.25mm.
Looking like this will work if the diff unit will fit and be properly adjustable for backlash and side preload. Will see when I get there. I may have a low-mile R180 CLSD (3.90) for sale if this works out.
iceman510
Post by iceman510 » 27 Jan 2020 18:50
I have been able to get back to this finally in recent weeks. I was able to swap the bearings to keep the original races, spacers etc. together in the original Nissan case. I am ready to attach the ring gear. I am still ruminating about the bolts.
I sleeved the LSD unit as discussed above to fit the original Nissan bolts. Those bolts are 21mm under the head and the thickness of the unit is 12mm, leaving about 9mm engagement in the ring gear. With the 1.25 mm thread pitch that provides about 7 threads of engagement, but not quite one bolt diameter. I am hesitating on this because of this quote from Kurt's old how to:
You MUST use either the Nissan Motorsports LSD 10mm x 1.25 ring gear bolt set (Part # 99996-D3100, bolts cost $8 each and you'll need 8 of them), or just BE SURE to use the bolts that came with the LSD unit, not the ones from the open differential whenever you do this or your LSD innards will chew themselves to pieces.
What does the bolt length and retention have to do with the clutch innards? Anyone understand the facts behind this assertion?
In addition I researched the recommended Subaru LSD bolts. This part number listed about (8002-11140) is shown in the parts catalog as 11x20x12.
Part Number: 800211140
64- LSD FOR VISCO LSD
11X20X12
Fits Baja, DL/GL/GL10/RS/RX, Forester, Impreza, Legacy, Outback, STI, SVX, WRX, XT
I am not very familiar with Subaru parts, but typically a bolt description is just diameter and length. Not sure what the extra number represents. Anyone have any of these bolts lying around or experience with them that knows the actual length? If they are only 20mm, hard to justify the change to these bolts for less insertion. The only difference would be greater thread engagement if they are 1.0mm thread pitch. It would only be about one thread difference. One more data point, the thread hole is about 15mm in depth.
Looking for some advice or empirical experience to consider in my decision.
Thanks.
Tedman
Post by Tedman » 17 Feb 2020 21:29
Nissan R200 ring gear bolts p/n 38102-N3100 are the same as the Nismo 99996-D3100 bolts. I ordered a set From Courtesy Nissan ($4.30 ea) in June 2018 to replace the ones in my R160 with Nissan Comp LSD when I had it rebuilt. It's been working just fine.
Edit- Just measured one and the bolt shank plus threads is 22mm under the head.
iceman510
Post by iceman510 » 18 Feb 2020 09:33
Ted, thanks for that nugget of information. That is very helpful and should resolve my dilemma. I should have thought about checking some other vehicles that have offered LSD units. I am trying now to get exact dimensional specs on that bolt, but the length measurement sounds like a winner.
I did reassemble the ring gear with the original bolts already. I'll guess I'll check the Loctite hold on them after a few weeks when I replace them with the longer bolts.
Tedman
Post by Tedman » 19 Feb 2020 10:58
Glad to help. I learned about the R200 bolts from Robert Johnson. That dude's full of nuggets! Also, FWIW, my '98-'99 Motorsports catalog confirms that the 9/6-D3100 bolts are 22mm long M10x1.25 and used for both R160 and R180 when an LSD is installed. I believe it is because the LSD flange is a bit thicker.
