If you need a picture, send me your email address (or text number) and I can do that. Otherwise there's just too much here to post pictures of.
For pricing, let me know what you're interested in and we'll work out a deal. Thanks!
Shipping to Abbotsford, B.C., can probably be arranged for the weekend of Sept 20.
• LF fiberglas fender w/ 1 crack, easily repairable
• Front cross-member (LCA pivots welded on)
• Grille support pieces (vertical stamping, behind centre of grill), excellent condition--2
• Hood hinges, excellent condition—1 pair
• Hood latch—1 complete set (top & bottom pieces) SOLD
• Hood latch, upper portion only (attaches to hood)—2
• Hood prop rod & spring—1 SOLD
• Hood release cable in very good condition, incl. rubber grommet—1 SOLD
• Under-hood stainless trim in v good condition (front face perfect; small imperfections in lower face) 1 SOLD, 1 remaining
• Set of complete doors for 4-door sedan, excellent condition, incl. glass, window mechanism, internal & external door handles, grab-handles (rear), door cards (but missing the lock cylinders on the front doors)
• Gas door in excellent condition—1
• Gas door in good condition (hinge re-welded)—1
• Gas filler tube (metal) in excellent condition--1
• Gas filler rubber elbow, between metal inlet plate & metal pipe, excellent condition--1 SOLD
• Gas filler inlet plate and gas cap, excellent condition—1
• Drip rails—complete set in excellent condition
• Chrome trim strips for exterior of the doors of 4-door sedans, chrome in excellent condition but needs new rubber—LF, LR, RF (missing: RR)
• “Datsun” script—2 pairs in fair condition (1 pair plastic, 1 pair metal, all pieces with some pitting & broken pins)
• Tail-light wiring harness in good condition—1 side
• Tail-light buckets (white plastic), R side, in good condition (plastic hardened, w/ slight crumbling) SOLD
• Tail-light bucket (white plastic), L side, in fair condition (plastic hardened, w/ some crumbling)
• Tail-light lenses, R side, in good condition—2 (1 has slight crack that’s been repaired; 1 has minor rust-staining inside clear lens)
• Tail-light “inner” chrome trim, good condition (minor pitting) SOLD
• RED marker lights, incl. metal “buckets” in exc. condition (zero rust), rubber gasket in v good cond (soft, no cracks), SS trim w/ no dents, plastic lenses in exc. condition (no cracks, v minimal scratching), missing most of the screws— 2
• Marker light plastic “buckets” (!! non-rusting!!) in excellent condition—2
• Front turn-signal light, L side only, in fair cond (1 crack in lens; gasket somewhat perished)—1
• Stock wiper motor, working condition
• Complete wiper linkage, working (everything pivots)— SOLD
• Stock washer bottle—SOLD
• Stock battery trays (rubber, with raised lip around edge)—3
Parts for sale-- body & shell
- SteveEdmonton
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Re: Parts for sale-- body & shell
Hi Steve,
I am interested in the under hood trim. PM on its way.
- SteveEdmonton
Hi Luis-- here's a link to my earlier ad for this under hood trim, including some pictures. http://the510realm.com/viewtopic.php?f= ... im#p272542 Texting works great, thanks for getting ahold of me that way.
Checrs, Steve
Checrs, Steve
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Any chance you've got early wiper arms for one?
- SteveEdmonton
I do have wiper arms, yes, but I'm pretty sure they're from one of my 70-73 parts cars. If the earlier arms are different, I don't think these would do the job. Sorry.
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
1968 are 68 only. USA spec LHD 69-73 should be the same. Remember, the cap nuts that hold the arms to the wheelbox stud are separate.......example the Z car cap nuts are kinda captive in the arm, so if you don't have the correct 510 cap nuts, you will need them too!.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
