libre lug nuts
Matt#2
libre lug nuts
Post by Matt#2 » 10 Jan 2020 20:54
Hi all
So I got my newly acquired 14x5.5 libres all cleaned up(thanks yenpit), tires mounted, all set to throw them on....lugs don't fit. And it's not the depth of the shank that's the issue, it's the bore size. After googling, it seems that the standard bore for 12x1.25 shank nuts is .68, however the hole in the rim is...best guess .62 (hard to tell, can't fit the caliper in there to measure). They don't look mis-shapen from previous damage. I don't get it.
What am I missing? Any thoughts?
Thanks.
cartel
Re: libre lug nuts
Post by cartel » 11 Jan 2020 17:00
turn on a lathe or try some other brand- could always have someone drill out the wheels but ive never had to do that- ive used open end moroso lugnuts before but i also convert to std thread studs usually, would be super easy to turn on a lathe to fit --
Mike Gibson
