Mikes 71 Flared SR20DET GT3 Pure Orange Gourd
Re: Mikes 71 Flared SR20DET GT3 Pure Orange Gourd
Those hose fittings look awesome. The crimps add some 'pro' to it for sure.
Stu
1972 4-door 510
2004 Volvo V70R 6spd manual
Factory Five Racing Cobra
1972 4-door 510
If your talking about the fuel line one.. I made a bracket from alum angle..and mounted it with 1/4× 20 nutserts. .. I went back and looked at the picture I think there is an existing nissan nut welded into the frame there as well .
So might not be nutserts added id have to look at it again.
Then just drilled and used 2 -6 AN bulkhead fittings .I usually use some grade 8 sae washers (they're a tighter fit) I recall having to use a die grinder to make them fit over the threads..
Cunifer 3/8 along Floorplan and then to -6 lines.
Feed goes direct to fuel rail and return to regulator. Then out of reg back to tank.
Mike Gibson
- eastbaysolo_73
Looking good man. Keep up the good work!!cartel wrote: ↑18 Oct 2020 11:28 intakes is on - fuellab regulator mounted , just spent yesterday crimping the brown and miller lines-- boy those are pricey! but they look awesome-- (slightly biased lol )
flex fuel sensor mounted under intake for E85 which will be able to tell ecu alcohol content to vary tune for timing and boost based off of that ..
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
Thanks for the info, It’s really well done. Nice work!cartel wrote: ↑19 Oct 2020 20:54 If your talking about the fuel line one.. I made a bracket from alum angle..and mounted it with 1/4× 20 nutserts. .. I went back and looked at the picture I think there is an existing nissan nut welded into the frame there as well .
Headlights in and IC piping done. Onto wiring this month..
- 20201117_152335_compress33.jpg (444.54 KiB) Viewed 2488 times
Mike Gibson
4 hours of sanding the part to test fit wiring panel..for Fatsun..
- 20201211_154611_resize_17.jpg (62.29 KiB) Viewed 2513 times
Mike Gibson
Integra wiper motor wired.. standalone harness.. deutsch connectors..
Fun part figuring out datsun switch with 5 black wires
- 20201215_171109_compress81.jpg (436.69 KiB) Viewed 2466 times
Mike Gibson
Where did you get those headlights and how much bucket cutting did you have to do?
Dapper lighting--you just missed a nov sale-- i can prob get you a small disc as ive bought 5 sets already--
NO cutting required -- i was a little overboard and cut the tabs of the back to center the lights and then a small bead of silicone to make sure theyre almost perfectly centered.. seems like on ALL old cars none of the new 5.75s seem to match the tabs to the headlight buckets-- had the same issue on a 67 chevelle and a 64
Mike Gibson
The lights look great. I like how you did the Integra wiper motor. I am thinking of adapting a late 80s / early 90's Ford truck variable intermittent to the Integra wiper. The issue is one is ground switched and the other is power switched. Think I have it figured out with a micro relay but not sure if the BIG Ford wiper switch will work. Finding a intermittent system from a 620 has proven elusive and/or stupid expensive
Stu
1972 4-door 510
1972 4-door 510
Started on tunnel mod for a stock 240sx shifter boot. Waterjet cut some rings to mount the boot . Measurements from fengshui 510..
Not sure if im going to do the cupholders yet.. those are going in Fatsun.. almost thinking of a rear cubby like a 240z came with at rear of console
- 20210107_181312_resize_77.jpg (627.78 KiB) Viewed 2306 times
- 20210107_181324_resize_11.jpg (667.9 KiB) Viewed 2306 times
Mike Gibson
finally got to making rad shroud.. was putting that off as wasn't looking forward to doing them..
single fan. offset.
single fan. offset.
- IMG-20210126-WA0005_resize_76.jpg (294.68 KiB) Viewed 2170 times
- IMG-20210130-WA0002_resize_46.jpg (291.82 KiB) Viewed 2170 times
- 20210130_171652_resize_55.jpg (380.8 KiB) Viewed 2170 times
- 20210130_171708_resize_49.jpg (418.98 KiB) Viewed 2170 times
Mike Gibson
exhaust almost done. converted downpipe to V band as well..
- 20210210_103536_resize_39.jpg (366.71 KiB) Viewed 2069 times
Mike Gibson
Looks great. Did you go with the v-band so you can take the exhaust out 'easily' when needed? When I get to my exhaust (will have to go somewhere) I will have them put in a flex joint but wondering if v-band would make my life easier in the future.
Stu
1972 4-door 510
1972 4-door 510
everything I work on now gets v bands.. even ol pumpkin got a full exhaust with 2.5 v band.
so much less grief in long run
Mike Gibson
