Has anyone tried one of these filler necks?
paul97
Post by paul97 »
I just found this filler neck and I thought about getting one for my 510 but I wanted to see if anyone has bought one before.
http://www.maddat.com.au/engine/1600-51 ... filler-kit
Re: Has anyone tried one of these filler necks?
Post by JordanTr »
That hose coupling looks an awful lot like silicone. I would be nervous putting that in my car unless the lining is made or rubber/fkm/Viton etc.
iceman510
Post by iceman510 »
Agreed. I would check with the seller. Silicone does not stand up to gasoline.
Post by Three B's Racing »
You really think Maddat would put out a product that will fry you and your car? This has to be inspected for use in Auz and has been and is good to go. I'd have no issues using that kit personally.
dodgydan
Post by dodgydan »
paul97
Post by paul97 »
dodgydan wrote: 15 Aug 2020 20:19 hay paul97 did you end up using http://www.maddat.com.au/engine/1600-51 ... filler-kit ?
Yes I bought one but no I haven't installed it yet because I am still working on the front end and engine bay right now. I hope to have it installed in the next few weeks and I will post a picture of it installed then.
dodgydan
Post by dodgydan »
great let us know how it works out. i have to do same repair as our rubber parts are harder than they should and show signs of cracking.
is the hose silicone or ???
paul97
Post by paul97 »
I finally installed the filler neck and it fit perfectly! I did trim the hose where it goes onto the fuel tank filler neck at an angle so it sat flush with the fuel tank. I even installed a charcoal canister which is in the first picture.
DSC09138 (640x480).jpg (65.65 KiB) Viewed 1284 times
DSC09136 (640x480).jpg (76.79 KiB) Viewed 1284 times
DSC09133 (640x480).jpg (67.14 KiB) Viewed 1284 times
tycot1
Post by tycot1 »
I am sure you can buy the hose through Lordco still. It is made by Greenline and comes in three different ways, soft, medium and hard. I have used the soft on a few cars and it works well.
edekalil
Post by edekalil »
That look real nice, I'm sure if concerned about the hose you could find one similar made of neoprene.
Stu
Post by Stu »
Where did you get the charcoal canister?
Stu
72 4-door 510
Factory Five Racing Cobra
2005 Mini Cooper S
91 Ford F250 4x4 extended cab
