Gilson SSS Dash Fitting method
Re: Gilson SSS Dash Fitting method
Thanks to all the posters who are doing their SSS dashes. Good info.
- eastbaysolo_73
Thanks for the write up. Just got my dash two days ago. Any one have a write up on how to wire up the turn signal indicator and hight beam light supplied with the dash? I have speed hut gauges in my car currently. Thanks in advance. Again great write up.
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
eastbaysolo_73:
See if you can get a replacement wiring harness for the turnsignal and splice into the 12 pin pug for the high beam. For the turn signals, cut off the light bulbs and wire them to the LED's. Be sure to observe the +12 and ground.
