Time for an update — New Year’s Resolution - FINISH THIS!
Over the past few months I have completed a few things; got hung up on a few others; but I am going to finish this in 2024! Ready to get this rolling!
Items completed:
- Installed Pedal Box
- Installed Master Cylinders
- Installed Brake and Clutch Pedals
- Installed Rear and Mid Sections of Exhaust
- Painted and Installed the steering column / Test fit new steering wheel and hub adapter
- Test Fit TSR Intercooler
- Installed Spark Plugs - NGX Iridium IX BKR8EIX
- Installed transmission yoke dust cover — which required removing the drive shaft (forgot it on assembly day)
- Reinstalled all the bolts on the transmission crossmember
- Installed new bolts on the drive shaft connection to the differential
Got some deals on Black Friday sales and ordered most of the electronics to get this running and boosted!:
- Haltech ECU and Wideband Controller
- Greddy Boost Controller
- Wiring Specialties Wiring Harness
- Injector Dynamics Injectors
- Smart Coil Packs
- SR20 Accelerator Cable
- AC Compressor Brackets
Working on:
- Modification to the stock accelerator pedal to adapt to SR20 Cable
- Brake lines / plumbing
- Installation of exhaust manifold, downpipe, turbo, wastegate
- Spec plumbing for turbo, intake manifold, heater core
Issues:
- E-brake cable loop in contact with exhaust
- The radiator hose solution for the cowl drain is not going to work - looking for another solution
- Undercoating / powder coating / paint in threads of many installation points - some requiring tap and die
- The AC condenser coil will need to be installed inside the fan shroud to avoid hitting the main pulleys - requires mods to fan shroud/radiator
- Will need new holes drilled for radiator installation
Some Pictures:
Pedal box and Master Cylinders:
From DP Racing:
- IMG_1320.jpeg (189.11 KiB) Viewed 377 times
- IMG_1315.jpeg (491.5 KiB) Viewed 377 times
- IMG_1317.jpeg (292.88 KiB) Viewed 377 times
- IMG_1316.jpeg (251.4 KiB) Viewed 377 times
Exhaust / Drive Shaft:
** Note E-brake cable - will need to be reworked - anyone have ideas — thinking about running direct cable so each wheel and re-run to clear exhaust, drive shaft, and IRS…
- IMG_1318.jpeg (275.53 KiB) Viewed 377 times
- IMG_1319.jpeg (204.75 KiB) Viewed 377 times
- IMG_3515.jpeg (439.4 KiB) Viewed 377 times
IC Fitment:
- IMG_1322.jpeg (117.92 KiB) Viewed 377 times
- IMG_1321.jpeg (167.04 KiB) Viewed 377 times
- IMG_2024-01-01-203028.jpeg (292.07 KiB) Viewed 377 times
Continued…
